Please, need help(clutch)
Clutch is not returning up. Bleed the brakes and the slave cylinder, using a bleeder pump. Car was running fine, parked and next day, clutch went down, only hand pulling, bring it up.
Any ideas? Thanks Carlos
torico |
meister member
Clutch slave cylinder leaking. Pull the starter and check for leakage around the seal.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Sorry, forgot to said, I replaced the clutch slave cylinder.
Thanks, for you fast response .
torico |
Hi, maybe your clutch master is at fault?
Usually a master cylinder leak causes the pedal to stick down.
Have a look under the pedals (and down the carpet.....) Replace both cylinders, pressure and feed hoses. You will need a pressure bleeder to properly bleed the system. Brake (and clutch) fluid should be changed every two years. Timing belt? Fuel pump (DME) relay changed too?
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
Maybe when you bleed the brakes you let the level in the tank get down low enough to get a air bubble in the line that feeds the clutch, they share the same reservoir. I bleed the brakes on one of our Isuzu NPR trucks, they have the same setup and got a air bubble but it did not stick to the floor, it would not disengage the clutch but maybe a Porsche will react differently. Try bleeding the clutch.
Brian 1983 Porsche 944 Silver with Brown Interior. 2005 Honda Goldwing 2000 Husaberg 400 2001 Sherco 2.9 1968 Honda CT-90 2001 Arctic Cat 500 Auto 1998 Toyota PU 2001 Toyota Highlander AWD 1991 Tiffin Motorcoach 2006 Suzuki 450 Super Motar |
Redline Racer
The MS seals might be bad even if it doesn't leak. Thats what happened to me last week. It was very random at first. It would feel fine most of the time and then just go to the floor for no reason. It got bad enough that I had to look into it. Nothing was leaking and bleeding the system didn't help. Turned out the MS wouldn't develop pressure.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky Last edited by HondaDustR; 02-18-2007 at 06:38 PM.. |
clutch
What is " Ms" and How difficult is to replace the MS.
I will work on this next weekend, Thanks to all , for you input. Carlos
torico |
clutch master cylinder. It gets the its fluid from the brake master. Follow the blue rubber hose (if yours is still original color) from the brake master tank and it will lead you to the clutch master cylinder. From the clutch master cylinder it follows a line to the clutch slave cylinder.
Automotive Necromancer
a very small amount of Spray silicone worked 4 me. Temperature may be a factor as well. it seems cold weather is not condusive to clutch bleeding.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
sorry to jump in here....but where is the bleed point for the clutch?
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Hi, bleed point is at the slave cylinder. Make sure though you don't suck down the brake resiviour though and get air into your clutch master cylinder because the clutch and brake share the same resiviour.
