Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
Brake Fluid Warning Light
Over the past couple nights, when it has been VERY cold (single digits), the brake fluid warning light has come on while I was driving home. During the day (temps in the 30s and sunny), there has been no warning light. When I check the fluid reservoir, it seems to have the correct amount of fluid. Brakes and clutch have been functioning normally.
Now, I'm guessing that the extreme cold is just messing with sensors a little bit, but is there anything I should be worried about?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 03-09-2007, 07:55 AM
bearone2's Avatar
"seems" there's a min/max line.
if you're close to the min line and the car cold soaks, the fluid level is lower than if you check when at operating temps.
as you drive, just like the water, the bf also warms up/expands.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 03-09-2007, 10:49 AM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
The brake fluid in my Subaru has been freezing, it's been so cold. Perhaps the brake fluid (or the moisture that has accumulated in the fluid) might be freezing up a little. Granted, the fluid in my Subaru is very very very old; I'm changing it over the summer.
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 03-09-2007, 08:17 PM
AFJuvat's Avatar
When was the last time you bled them? Did you use DOT 3 or DOT 4?
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 03-10-2007, 08:56 AM
