Banjo Bolts......SNAP!
Gotta share this. I'm in the process of doing my belts, and while down there noticed where the drop of ATF was coming from. There was a tiny leak in the line from the PS pump to the steering rack.
I couldn't source a new line, and it would be pretty expensive I'd guess, so took it to a mate and got it fixed for a case of beer. Cool. Just bolt it back on. Nah, you just gotta tighten everything that little bit more, and SNAP, the small bolt on the rack is #$%&ed. Living 100 kms from the nearest dealer, went back to my friends shop, and found one that fitted. It all looks good, but now can't check it till I start the motor, the new timing belt was ok, then I looked at the balance belt, and its 1/8th of an inch narrower than the old one. Melbourne to Perth is about 3000 kms, a four hour flight approx, so why has it taken a week since ordering and still hasn't arrived! I should have ordered through Pelican over there and it would have been here. Sorry, I got off track, If you ever play with banjo bolts, and new crush washers, BE GENTLE! Has anyone else found differences in balance belt widths from diffferent models?
Dave Jezza http://www.pelicanparts.com/gallery/jezza944 1984 944na Krystalgrun (Crystal Green) Last edited by jezza944; 03-12-2007 at 05:31 AM.. |
I have made a banjo bolt once in a crunch...
You could give it a shot, takes some patience and a steady hand. Havn't noticed any balance belt width issues :\
My cars for sale, due to move 1986 944 turbo - For sale. 1987 944 N/A - For sale. |
Redline Racer
Here's the info about the different balance belts.
http://forums.pelicanparts.com/showthread.php?threadid=335305
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
