callmethewander's Avatar
different tire ratio?
i have 215/60r15's on my '87. can i use a 215/55r15's? the sidewall is a little smaller so i guess the overall outside diameter would be smaller also, but would handling be better?
1991 cabriolet (sold)
1989 S2
1988 S
1987 944 n/a (sold)
1987 944 factory yellow (junked )
Old 03-21-2007, 02:59 PM
plus, the 55's seem to be more available.does this make any sense? what's affected and how? thx
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-21-2007, 03:04 PM
If you go to this web-site, you can do a comparison of your current tire size to any other size you choose:
http://www.miata.net/garage/tirecalc.html
Keep in mind, that if you lower the profile of your tire and do nothing else, the final diameter of your tire will be smaller and will therefore cause your speedometer will be off and read faster than actual.
Another way that people will go to lower profile tires is to also step up in rim size. On the link, you can compare your 215/60/15's to 225/50/16's and the final diameter will be the same and so very little speedometer effect.
To answer your original question: yes, the car will probably handle better.
Old 03-21-2007, 03:07 PM
Non Compos Mentis
Not enough difference between the 60 series and 55 series to worry about. No problem.
Old 03-21-2007, 03:20 PM
thank-you gentlemen, cool site too, perfect!
1989 S2
1988 S
1987 944 n/a (sold)
Old 03-21-2007, 06:34 PM
