-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Someplace that checks 968 Alternators (http://forums.pelicanparts.com/showthread.php?t=340440)
912E TKT 04-09-2007 08:50 PM
Hi,
I pulled my alternator and tried to get it checked at the local Kragens. They couldn't do it.
Anyone out there in the Pasadena CA area know where to get a 968 Alternator checked around here?
bearone2 04-10-2007 12:16 PM
i'm surprised they couldn't check it.
i think you might've run into someone who didn't know what they're doing.
many auto parts stores have universal type stands that accomadate most alternator/starters.
call another store and see if if you get the same response.
912E TKT 04-10-2007 01:09 PM
Okay so I found a rebuild shop on Foothill in East Pasadena called One Stop Auto Electric. They tested the alternator and it was cooked. They are doing a rebuild on my old one and it will be ready by 4:00 today. The rebuild is backed up for a year and cost 160.
legion 04-10-2007 01:41 PM
It's just a standard Bosch alternator. The same unit was used on Audis and Volkswagons. I had mine rebuilt a year ago for $70--but I did supply the voltage regulator.
912E TKT 04-10-2007 01:42 PM
I made the mistake of saying the word Porsche
legion 04-10-2007 01:58 PM
Yep, I told the shop mine was from an old VW.
(Sometimes that even gets you sympathy.)
912E TKT 04-11-2007 07:44 PM
Can anyone tell me which way to re-wire the starter on a 968? Does the largest cable attached to the upper or lower of the two primary connections on the solenoid?
legion 04-12-2007 06:00 AM
When I did it, I recall that the cables on the back of the alternator had either a large hole and a small hole, there was a corresponding large post and small post on the back of the alternator. (I believe the late 944 and 968 used the same alternator, correct?)
912E TKT 04-12-2007 06:46 AM
Hi
Yes I see that there is only one way to wire the alternator, my question was about the Starter on the 968. I just need a double chek on where the two larger cables go on it.
