Where is the ignition switch 944
I need to check if its faulty, can anyone describe where it is on a 944S??
hmm... isn't it in the column?
Might have one of those rare ones that doesn't have one. Kind of like the 944 that would run with the reference sensor and fuel pump disconnected.
Several months back. Think it was a troll. Very creative and with what appeared to be sound arguments at first glance.
As to this threads question: The ignition switch is at the end of the key in the steering column. Check out www.clarks-garage.com for the procedure to remove it. Different between early and later 944's. |
| All times are GMT -8. The time now is 07:51 PM. |
