Where is the ignition switch 944
I need to check if its faulty, can anyone describe where it is on a 944S??
winter-hater club member
hmm... isn't it in the column?
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Might have one of those rare ones that doesn't have one. Kind of like the 944 that would run with the reference sensor and fuel pump disconnected.
Hugh - So Cal 83 944 Driver Person NOT a 'real' Porsche -- Its Better!!!! When was the last time you changed your timing and balance belts and/or cam chain and tensioner? New Users please add your car's year and model to your signature line! Never break more than you fix! |
Several months back. Think it was a troll. Very creative and with what appeared to be sound arguments at first glance.
As to this threads question: The ignition switch is at the end of the key in the steering column. Check out www.clarks-garage.com for the procedure to remove it. Different between early and later 944's.
