LED Cluster Mod
In my pursuit of better light in the cluster I found a product that works pretty good and costs under $25. This is an LED Flexi-Lite distributed by Pilot Automotive. Its the best low profile LED strip out there. Its 10" long and has double sick tape on the back. I would have preferred white but the blue is all that was available. Lemme tell you this thing is brite and is very noticeable from the exterior. I will eventually get the white which is harder to find. The part number is CZ-180B the white is CZ-180W. You may find at Pep Boys or Autozone. The white you wont find however I have a lead on where to find. Heres a sample
[img]http://forums.pelicanparts.com/uploads10/LED+cluster1178949630.jpg[/img]
88 928 S4 Black, Black and Grey Interior Alpine head unit & amp, Bazooka Tube, Viper 5704 Smart Start GPS tracking, Devek Headers, Flowmaster 40 3" with Resonator, Auto Authority chips. Custom Luggage Cover. Traded - 86 944 Turbo Guards Red. RIP - 85.5 944 Guards Red |
Super Moderator
ahh nice !
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
Super Moderator
how did you hook this up? is it dimmable using the stock dimmer dial? did you have to remove the dash?
Somehow my audio guy hooked it up to the dimmer and just had to remove the cluster surround and cluster then remove the glaas to get the strip in there with holes on the side for the wiring.
i see kids doing this all the time, and chalk it up to inexperience or one of those "bling / fad" things
this is a dangerous and ill advised mod - bright dash lights lead to pupil reduction and poorer night vision - you should run your dash lights as dim as poosible and still be able to read the guages there is a VERY lengthy government study on lights and the effects they have on the human eye and its capacity to see at night - it clearly shows the detrimental effects of bright lights, both dash and oncoming headlights truck drivers have known about this for decades - most of them drive with their dash lights off or nearly off |
Garage Helper
There are also a couple of different kits out there for re-mirroring your cluster - that's how they get dim after the years, the mirror effect is all but gone - With the mirror kits you just polish to clear the old mirror channels (Been quite sometime since I have done mine, but I remember there were four mirror channels that need to be re-done). Pretty easy to re-do with these kits as they send complete instructions and a sheet of the mirror material that you cut to fit and adhere to the cleaned mirror channels. The kits come with new bulbs to replace all of the old ones. So replace all of the bulbs (4) mount the mirror material, and reassemble the gauge pod in the dash. The gauges are now back to factory new bright, plus the dimmer works as it should.
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now). ![]() UAV-M1 (Urban Assault Vehicle - Model 1) Bless the lowered, and pass the nitromethane. Pedal to the metal till you see the gates of hell then brake NLA - No longer available is a four letter word |
[QUOTE=flash968;3466746]
this is a dangerous and ill advised mod - bright dash lights lead to pupil reduction and poorer night vision - you should run your dash lights as dim as poosible and still be able to read the guages Got to agree with you on this one,here is mine which are the original dash ligths with the dimer at 100%. ![]()
83-944 show room -sold___New ride 93-968 with SC steering wheel-ROW signal ligths- Susp M030 mods lowered,Porsche VA springs- Adjustable struts - Bilstein inserts - Bilstein sport rear -LSD -riding on Cup 1 wheels 17x8 frt 17x9.5 rear road contact Falken 452/ 225-45 ZR Front 255-40 ZR Rear -- Motor Mods /chip /K&N / mod air boxe just love the handling & power
944 addict
Is there any small 12v black light bulbs that could be used? It would really make the numbers and markings stand out without blinding the driver.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
AFM #725
The lights in my 944 dash seem just fine
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
86 951 blk |
I have one of these installed by the PO in my 85.5 and the dimmer does not work. I have never tried to investigate why. Also I think it is too bright and affects my night vision. My 87 is fine stock.
on ebay from 9xauto
I think the dash lights are the least of problems regarding loss of night vision.
There is no way they affect your vision at night more than your own headlights, onco,ming lights, reflection from signs, streetlights, etc. Even on a moonless night in the middle of the desert,your own headlights reflect more light than your dash lights. Sorry, just don't believe this " extensive government study" exists.
87 951 all stock exc. cup II's /94 968 6-spd, lowered,17in. RUF Speedlines, M030 anti- sways/ 94 968 Tip, Cup II's, otherwise stock |
Super Moderator
imo glare is just part of driving a sports car. Being lower than 90% of the cars on the road I get more glare in my rear view mirror from SUV's and trucks than anything my dash can throw at me.
AFM #725
I tried black light bulbs...the numbers did not want to glow at all the needles did though... Just my 2 cent
