meister member
speedracing944's Avatar
How lean during cruising using Mega Squirt II
For those who have rigged up thier 944 with MS ummmmm....ae1969 How lean can you go during low MAP and around 2600 RPM? I am thinking cruising speed of about 65 MPH. What AFR are you running about there? What are the EGT around there with your given AFR?
For the past year I have been putting in $600 worth of gas a month in my 944 and am getting between 22 and 26 MPG. Can I use the MS and a wideband to get leaner mixtures and squeeze a little for fuel mileage out of my '83?
I'm thinking cost savings here with the added benefit of MS at the top end
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 06-04-2007, 10:33 AM
SoCal Driver's Avatar
Lean it till there is a small hole in each piston then richen it a half turn.
Actually you need a knock sensor or two to be accurate. Kind of like the 'S' model.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-04-2007, 11:27 AM
meister member
You can use a knock sensor as well but it will pick up knocking (detonation) but that is after it starts knocking which is what I don't want to do. With the knock sensor it tells me 2 things. Knock or no knock. Using the EGT sensor will give me a gauge to tell me how close I am to the line without going over.
IIRC based off my old dyno sheet at cruising the AFR on my '83 was about 16:1
Speedy
Old 06-04-2007, 11:55 AM
cold starter
JustinL's Avatar
I run mine at 14.7 with 4% ego correction so it oscillates up and down a bit.
**I'm not an engineer and they can feel free to correct me**
Detonation should not be a concern at cruising loads. The cylinder pressure is relatively low and unless you get insane heat build up should not be a factor. I've heard of guys leaning out the mixture as much as possible to improve fuel economy, though I don't subscribe to that theory. I've found that as I get leaner (above 16:1) on deceleration I get lots of popping from the exhaust. This is because there is not enough fuel to get good flame propagation in the cylinder and you end up pumping fuel into the exhaust system where it ignites and pops. Because of this I feel that if the fuel isn't burning in the cylinder, it must not be as efficient.
88 Turbo S Silver rose: Megasquirted fuel, assorted suspension upgrades, etc.
89 944 S2 with 968 engine: Race car
87 944: Chump car build in progress
Old 06-04-2007, 02:21 PM
Shut off the fuel on deceleration.
Old 06-04-2007, 06:44 PM
cold starter
JustinL's Avatar
I shut it off if I'm trying to conserve fuel, run it lean if I'm trying to maximize spool in between shifts, and stoich when I'm on the track to reduce engine braking on lift off.
Old 06-04-2007, 08:14 PM
meister member
I am looking at my dyno sheet for my '83 and with the stock engine computer the car is running at 16.2:1 ratio from 2500 rpm - 4300 rpm.
After 4300 rpm it drops to 13.7:1 and continues to drop to 13.2:1 at 6400 rpm.
So I guess I am already running pretty lean at the lower end of the rpm range.
I guess I want to play the AFR Limbo. How lean can you go???
Speedy
Old 06-04-2007, 09:25 PM
Cars & Coffee Killer
legion's Avatar
This is exactly why running lean has a tendency to burn up exhaust valves.
5 liters of VVT fury now
-Chris
Old 06-05-2007, 05:46 AM
