meister member
speedracing944's Avatar
That sucks. How tight were the lug nuts on in the first place? Could they have been way over tightend before they even touched the car? If so I wouldn't hate on the shop too much. I always use a torque wrench when intstalling my lug nut for this reason.
Is your Fuch messed up or just your lug nuts and studs?
If they messed up my Fuchs I would be pissed.
Good luck Rich
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 06-30-2007, 04:45 AM
legoland951's Avatar
I remember America's Tire Company using 96 ftlb of torque for these lugs, which seemed high for these lightweight Al lugs but I am sure they did their research as they install tires on many 911 and 944s including race cars at their Torrance Ca location.
There is no mechanical task so great that brute force and ignorance cannot overcome
Old 06-30-2007, 07:56 AM
Politically Incorrect
onZedge's Avatar
Use never-seez on the treads and the cone of the nut. You get accurate stud tension AND the nuts will come off as they are supposed to. 96 ftlb is correct.
Edek
'87 924S
'91 535i
Old 06-30-2007, 02:50 PM
