headlites & fog lights
Hi does any one know if the headlights on a 1993, 968 are glass or glass with a plastic coating for protection? Also the fog lights are they glass? I want to clean them as they are showing their age and are yellowing for UV light. Any one have a cleaning product that they found to be very good to clean these? Do you use a polishing machine? Thanks
1993 968- Midnight Blue, Grey interior, tiptronic, 31,000 miles, concours winner, won two more throphies now have 31,489 miles |
Cars & Coffee Killer
I believe they are all glass. However, the stock headlights are sealed-beam units and could have been replaced with something else.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
all glass - not actually a sealed beam - they consist of a lens/housing and a separate bulb
no easy way to clean them - you can remove the bulb and get in there with a scrub brush, but it is no easy task - the glass is bonded to the plastic housing, so it is pretty tough - on top of that the flutes make it extra difficult make very sure the inside is dry, and free of any vapors before lighting them back up |
968 headlights
Thanks for the info, I think I will only clean the out side I am afraid I may screw up the working if I try and clean the inside. Keep on driving!
