help me get my 951 going!
I bought a 951 a while ago that had sat for quite a time. It's been partly disassembled but I've got it mostly back together. I have some questions about the alarm and etc though.
1: The keyhole in the driver's doorjamb is disconnected, and doesn't even have a plastic piece to go into... I have the keyhole but there's just 4 loose wires in the door jamb and only two plugs in the lock. Two of the wires in the doorjamb have female spade connectors and the other two don't, if I just hook these up to it will that disable the alarm? If not, or I can't get it to work, how else can I disable the alarm so that I can start the car? 2: Is there any way to drain the fuel tank? If not I'll just take a fuel line off and pump the gas out, but I'd much rather drain it from the bottom. I didn't see one but there's part of the (plastic?) gas tank that I couldn't see. 3: Anything else to watch out for? 4: is there a copy of the FSM online somewhere? I don't even have a workshop manual for this car at this point which is a big pain.
Go to clarks-garage.com his workshop manuels cover almost all work you can do on a 944
George
'87 944na '86 951 |
