Engine Help Needed
Hi,
I'm in South Wales and my 944S' timing belt's snapped. Anyone interested in helping fix it? just htought I'd be cheeky and ask... any help would be really appreciated.:( |
If your timing belt snaped your head valves are probably bent. IF so, you would need to remove the Head and send it off to shop for repair and valve replavement. Leak down test would tell you if you can find someone with pressure tank and right fittings/guages.
And if the that's the case, I would probably pull the whole engine and replace all seals and piston rings. Yes sir that's gonna cost alot of royal coin. But maybe you got lucky. Good luck dude, |
| All times are GMT -8. The time now is 10:22 PM. |
