scintaar's Avatar
Engine Help Needed
Hi,
I'm in South Wales and my 944S' timing belt's snapped.
Anyone interested in helping fix it?
just htought I'd be cheeky and ask... any help would be really appreciated.
... you don't need eyes to see, you need vision!
95 Mitsubishi FTO V6 MIVEC
88 944s
92 BMW 320i - E36
88 BMW 320i - E30
Old 09-11-2007, 05:14 AM
If your timing belt snaped your head valves are probably bent. IF so, you would need to remove the Head and send it off to shop for repair and valve replavement. Leak down test would tell you if you can find someone with pressure tank and right fittings/guages.
And if the that's the case, I would probably pull the whole engine and replace all seals and piston rings. Yes sir that's gonna cost alot of royal coin. But maybe you got lucky.
Good luck dude,
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 09-11-2007, 06:12 PM
