Cant stop the heat!
86 944- heat pouring out of the vents. blower motor is off & temp is on cold. feels like it could be coming from the engine compartment. Any ideas?
winter-hater club member
stuck vacuum switch at the firewall, perhaps, keeping the interior heat on.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
interesting, I get heat thru the driver side vent when the blower is off and the switch is set for recirculate. the other vents are ambient.
Engine swap pro
heater valve could be failing they fail on full heat. and your ducting could be messed up or routed wrong i dont know how that would be possable. or maybe the recirc flapper for the drivers side is not working and the heater valve failed hence heat on that one side.
87 951 ---- "R2" - under the knife 87 951 ---- "R1" Parting out - Gave to a good friend 88 951 ---- Black one - recieved as a trade for my 87 - very mint - parting out 06 WRX ---- The "RUE" |
The exact same thing happened to me... easy fix. There is a flap that mixes your cold air and hot air that is controlled by a motor and a push arm down by your right leg when sitting in the driver's seat. If the plastic clip that holds the control arm to the motor breaks (which is what happened to me) then you get constant heat ALL the time.
Here is the fix: http://www.clarks-garage.com/shop-manual/hvac-01.htm Scroll all the way to the bottom till you see this:
1989 944 n/a |
That Guy
Ah yes, the infamous heater clip. Mine broke this past weekend. I drove home in 2 hours of traffic, 80 degrees...not bad but it was something like 80% humidity that day. I was DYING in the car, jeans on and a black shirt... horrible horrible drive home. I was going to divert course home to the emergency room to be treated for heat stroke. The only time i ever wished i hadnt taken my a/c out...
. For the time being, you can ziptie the rod to whats left of the plastic clip...as you wait for your $2 part to be shipped to you via UPS for $7 .
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 10-09-2007 at 09:34 AM.. |
