-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   83 944 automatic vibration (http://forums.pelicanparts.com/showthread.php?t=376460)
jackd2001 11-09-2007 07:37 AM
I just purchased a 1983 944 automatic with 125k miles
I am getting vibration (rumbling) when the car is in reverse or drive. the idle is smooth in park or neutral.
Any ideas out there what the fix may be
Thanks in advance
carsontc 11-11-2007 01:07 PM
first guess would be the rubber damper...it's located where a clutch would be on a 5 speed.
http://www.pelicanparts.com/PartsLookup/HTML/944_2_USA_85_88_KATALOG/307-00-Frame3.htm
it is item #21. btw...item #25 (snap ring) must be removed before the drive shaft can come out.
