Throttle response mod
Anybody fitted it?whats the difference ? and will it fit a 16v S2?
Thanks Mark
Old 11-10-2007, 08:45 AM
thoen's Avatar
if you are talking about the response cam, yes. it is a great improvement and should fit all 944s.
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 11-10-2007, 10:25 AM
Yeh thats the one ,but after haveing a look round the net its only for 8v cars
is this true?
mark
Old 11-10-2007, 10:30 AM
thoen's Avatar
if the 16v cam is different, then i guess they don't fit. look at a 8v throttle cam and see if it is like yours. i can't see a reason for them being different in NA cars.
Old 11-10-2007, 10:42 AM
your average wrencher...
they are only for the 8v cars because the s and s2 use a pulley for the linkage, then routed directly to a throttle body, nothing like a pulley on an 8v
but they do work on 924S's because they have the 8v 944 engine
i know on my 944s it won't work, checked into it already.......my throttle cable comes from the firewall and wraps around a pulley to direct it back to the firewall to the throttle body. the goofy intake on those cars is annoying, everything is backwards....
hope this helps clear some confusion
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 11-10-2007, 10:58 AM
Ok thanks had a quick look and its no go ,they are for they 8v cars only
mark
Old 11-11-2007, 08:56 AM
Quality
phoenix_iii's Avatar
Porsche Crest
Can you link to it? Who sells it? Easy to install? What kind of improvement are we talking (how would you measure that?)? =)
Old 11-13-2007, 03:26 PM
That Guy
Techno Duck's Avatar
http://www.rennbay.com/throttle-cam-c-53.html
No gains at all. It just makes the throttle more sensitive.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-13-2007, 04:57 PM
Redline Racer
HondaDustR's Avatar
No, really!! It actually adds 10 hp.
I think you can just cut the stock one for the same effect. It'll just cut out the mushy off idle response. I find it easier to drive once you get used to it.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-13-2007, 10:34 PM
mr. dude's Avatar
This explains it pretty well....
http://www.dietersmotorsports.com/tech/2001/944_throttle_cam.htm
2006 Porsche Cayman S
2006 Lotus Exige (Sold)
1986 Porsche 944 (Sold)
1981 Porsche 931 (Wrecked)
1987 Porsche 944 (Sold)
Old 11-14-2007, 06:54 AM
Misunderstood User
I have modified my throttle cam as outlined in the attached article. The new hole location is right on. The trick to this is how much metal to remove to have this dual position. It takes some trial and error. Need a dremmel tool with a cut off wheel to remove the metal.
Other option to cut off the extended part of the cam and relocate the hole.
There is no HP gain, only better response from the throttle.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 11-14-2007, 09:40 AM
gtroth's Avatar
The S throttle cam is already round from the factory. I bet the S2 is the same.
1995 993C4 guards red
1988 944S alpine white
Old 11-15-2007, 09:49 AM
The S2 is not the same as either engine... the S2 is a direct wire from the throttle to the airflow housing.
Marcone
~87 Turbo ... Vandalized.. now a parts car.
~89 s2 16v ... Getting back on the road soon.
~89 Turbo S ... I GOT ONE.. Hidden away in storage!!
~04 Cayenne S ...
Old 11-19-2007, 10:29 AM
