87' 944S Timing / cam gear cover problem
I was changing my water pump, timing belt last nite and noticed that the rear cover behind the camshaft gear is broken at the mounting tabs. I took a look at the distributor cap and seen that it is barely making contact with the rotor contacts...
I took off the camshaft gear and this is what I have.. I don't think it can be fixed, I really don't know how this happens to a cover that is completely covered up. Maybe someone over tightened the 2 10mm bolts and cracked the tabs. 1 tab is completely broken off and the other one is cracked and bent upward. It has been this way for a long time, it almost looks like it has started to corrode away. There is no way that I can "just" put it back on without some modifing the tabs and cover to fit again.I checked Pelican parts, Zims and a few other places on the net and it is NLA at all the sites. It is #28 on the attached photo from pelican parts. Does anyone know if I can "fix" it by getting it welded and if someone has one for sale?? Thank you in advance for any help..... ![]()
can you drill it out from behind and stick a bolt through and use a nut on the front?
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked )
There's people parting cars all the time. Someone should have one for sale you'd think...
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you... 1994 BMW 325is M-Technic 1986 Porsche 944 N/A |
Used & Abused
clean it up, JB weld it
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
meister member
I vote finding one off a parts car.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party 1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II Check on progress ---> www.porschehybrids.com/gallery/speedracing944 Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run) |
Parts car, Or JB weld works and is very strong
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
hey, IDK, how bout throwin' some pix of the Karman up here, we'd love to see 'em.
I am in the process of finding a suitable replacement, but I won't overlook the cheaper fix.
I thought of cutting off the tabs and finding a "spacer" that is the same length as the broken tabs. Drill it out and nut and bolt it up. I have sometime to look since I have any extra car to use while I work on the 944. |
but, there is no substitute
Finally got around to writing an update..
I purchased a used cover from a local guy that just happened to have it "laying" around. $30 for both sides of the cover. ![]() While I was down for a while I took off the valve cover and had it Powder Coated Silver and painted that used timing gear cover. I also changed the Cam belt, balance shaft belt and water pump. And since I am never happy with stock I also "made" a custom 3" cold air intake for my S. pics to follow ![]() ![]() ![]()
Where is your timing gear and balance shaft belt cover?!?!
Why? doesn't that should be on there?(sic)
