Possible bad thermo-fan switch?
The cooling fans have started not coming on at all. Could the thermo-fan switch be the culprit. I know it can go bad and make them always run... had that happen last summer.
Old 01-07-2008, 03:01 PM
Send a message via AIM to bholmes
It's worth a shot. Could get lucky and just be a lose connection or broken/shorted wire. My car started to do some overheating tricks last summer. I repaced alot more than the switch, but I'm pretty sure that was the culprit. Someone had mangled an early fan switch onto my late 944 and that was most definatly the problem. Mine would either run alot when the car was shut off....like for hours and then it wouldn't kick on enough when the car was running and it would almost overheat every time. I put a new water pump, low temp thermostat and low temp fan switch and didn't have a lick of trouble (with that) afterwards. If you go low temp fan switch I have read that you need to use a low temp thermostat otherwise the fans will be overworked since the thermostat and fan switch would be set for different temps/cooling cycles. G'luck!
Brian
'86 944 NA
'94 Jeep Cherokee 3" and 31's
'86 Chevy C10 425hp
'98 Dodge Neon (the wife)
Old 01-07-2008, 04:36 PM
in denial
juVius's Avatar
take the plugs off the switch and jumper them.... if your fans run.. then it's the switch...
Steve - 83 944 (auto)
http://i136.photobucket.com/albums/q...s/blue/sig.jpg
Old 01-07-2008, 05:19 PM
Custom User Title
mikepellegrini's Avatar
From Clark's GSM: http://www.clarks-garage.com/shop-manual/cool-01.htm
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 01-07-2008, 05:30 PM
thanks ill try that when i get a chance
Old 01-07-2008, 08:41 PM
hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
I thought I had the sam problem with mine a few weeks ago. Do check out the Clarks trouble shooting. That way you can tell if it is your fans, relays etc. Luckly mine was just a ground issue with some other electrical problems. But thats how you learn more about the car!
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 01-17-2008, 05:29 PM
nope it was the switch... changed it and now its fine
Old 01-17-2008, 07:05 PM
