Oil leaks
Well, I figured that while I had the head off I might as well find the oil leaks that have been driving me nuts. I thought the front main seal and the balance shat seals were the culprit but they look mostly dry. It appears that the top balance shaft O-ring was leaking very badly so I will change it as well. I am puzzled by the amount of oil at the back of the balance shaft. So, I popped the balance shaft cover off and found the O-ring back there that I will change also. There also seems to be oil coming out of the oil filler assembly but I am not sure. Is the oil fill assembly prone to leaking? It is not shown in my Haynes manual so I am not sure how it comes off (or if it is even supposed to come off) but it looks like there are at least two bolts holding it down. Suggestions?
Thanks!
Rusty '83 NA 944 |
I have a 924 NA, but my oil fill caps leaks sometimes as well. Id say you might as well buy a new one, I think they are fairly inexpensive.
1978 Porsche 924 NA |
