DME Relay, No Start, Battery...Some Tests
Did some more testing on the no-start situation on my car. Few precise questions this time. Might actually be two completely different problems creeping into each other.
The DME Relay
The Battery
After Turnoff...
Questions...
Hi, my 83 944 has a battery drain and the easiest thing for me to do was narrow it done to the 3 factory power wires going to my positive battery terminal under the hood and interrupting it by putting a switch inside the car with a correct gauge wire below the ignition switch and turning it off or on when I have to start or stop the engine. Basically put a switch and am cutting out the circut and completing the loop so to speak. I have heard of factory 944 alarms doing the battery drain thing but like I said this was easiest for me to do and still does the trick years later. Alos, a diode can go bad in the alternator and drain a battery as well. Maybe you jumped your battery and messed the alternator up? You may also want to do some relay tracing. Can' help on your fuel issue though.
Trying to work for parts!
That hissing sound isn't good. focus on that for now. Battery issue is easier to fix...replace it.
For the hissing, have you checked the FPR/dampers yet? If not do that. If I had some extra's I would send them to you. Also, you might want to get a noid tester to check to see if power is getting to the injectors. It's sounding more and more like your having a fuel issue. Injectors could also be bad/going bad. Check each one when it's cold by putting 12+ & - to the terminals. you should hear them click on/off. If not it's definatly bad. Remember the fpr/damber are vacuum feed as well, so check your vacuum connections.
86 Metallic Grey 85.5 Metallic graphite - Gone |
Also, why not take the alternator off and have Autozone/Parts America test them for you? They do it for free. Same with starter & battery if your adventerous enough. All those test good, then you could simply have bad battery cables. After 20+ years they usually are bad.
How would I go about checking the FPR and FPD without the fuel gauge being hooked up? What test can I do to see if they're working properly?
Battery is 4-6 months old. Alternator was tested and new regulators put into place. Negative cable was replaced as well. New starter solenoid, two starters, cleaned all contacts in the starter circuit. Haven't replaced the positive cable since it's big and embedded into the wiring harness. As for vacuum, there might be a small leak. We've noted some peculiar problems occasionally that all lead to vacuum. I want to replace the entire vacuum system in the engine bay, all those hoses and elbows and junk with new ones. Can I purchase the hose anywhere in a roll or something? The elbows and y-joints Advance Auto didn't have, nor the correct hose diameter. Last edited by exitwound; 01-25-2008 at 04:30 PM.. |
Lindsey racing has a complete kit for the vacuum lines. Everything you will need.
Basically put the car back together. try to start the car. If no start, go to the fpr & damper. Disconnect the vaccum hoses and see if there is any gas in them. That's the one way I know how to test them. Otherwise see if there is anything on Clarks-garage.com about them.
Update: First day I could work on it was today.
Hmmm. DME intermittant? Still can't test fuel pressure at the rail. Can't find a local supplier for the fuel pressure gauge converter. RAWR. I think I'm dealing with two issues: no/low fuel pressure, battery drainage. |
Here is how I do it. I take the battery cable off the battery. I get a meter with a 10 amp reading and clip the negative lead on the battery post and the positive lead on the battery cable you just took off. This will tell you the amperage traveling through the meter. Should be less than 100 mA. Actually ideal is around 60 I think. Car should not be running and all doors should be shut and all lights off. Anything that should be shut off normally over night should be off. That will give you an indication of how much electricity is being pulled while it's sitting overnight in the driveway.
You may want to check your engine temp sending unit to make sure it's working properly. It tells the DME whether the engine is cold or not and may not be informing the DME correctly. 1200 for a warm idle is a bit high I think.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
Hi, with my battery drain problem I could have a volt meter to my + and - on the battery posts for awhile and I could actually see the battery being drained slowly but surely. I have a VDO gauge that mounts to the end of the fuel rail and you can borrow it if you pay postage both ways and promise to get it back to me. Ed from Ohio.
Well a parasitic drain test on the battery isnt possible tonight as my Multimeter has a blown fuse in it. Only local shop who has them closes at 4:30. Who closes at 4:30??? RAWR.
I'll test tomorrow. Zedsn, thanks for the offer. I will keep it in mind. |
