J1NX3D's Avatar
'88 944
With finding a new good head for my 924 turbo almost impossible, i've decided to shelve it and join the 944 crowd. I was actually shopping for an '89 944 2.7L, an S2 or a 6 spd 968 but this one was so tidy I had to go have a look, especially as I knew this car and it being 5 mins down the road.
Just had a look at this beautiful old 944. its an '88 with 111,000km. its very original with everything you'd expect with those km's. the seller has owned it since '96/80,000kms and the owner before that bought new.
cant remember what colour they call this... sage green metallic? with black interior and blue porsche script cloth seats. drivers side bolster is showing signs of wear but otherwise the interior is perfect including the dash. It also has no sunroof.
It was maintained by a reputable porsche dealer under the first owner. Said dealer installed air con before they sold it on to the current owner. This owner took it to another reputable porsche worshop who i've dealt with quite a bit in the past.
its had some work but not much. new cambelt at 66,000kms, some minor work to reduce tappet noise, new shocks up front. the underside looks new with a bit road grime from irregular use. When the head was opened up for said work the porsche workshop said it was like new with almost no wear.
waterpump and clutch are original. the tyres are good dunlops with good tread.
it drives really good, feels tight and stops on a dime. never driven one with power steering before and that feels good also.
so, is there anything I should be careful of with a 944 that doesn't get used everyday?
https://www.instagram.com/kiwi944s3/
'86 944S3 conversion
- '94 968 3.0 engine
- 6 spd/LSD
- 17x8,17x9 Oz Racing Crono wheels
Old 02-23-2008, 08:23 PM
Dtchy's Avatar
Nice car you picked up!
I would suggest keeping an eye on the waterpump and timing/balance belt. They're coming up on your maintenance schedule.
Have fun, you'll love the 944.
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 02-23-2008, 11:11 PM
GreenWater's Avatar
Did the PO let the car sit for a while before you got it? If the car has not been used for a while then the belts should probably be replaced just so nothing really bad happens.
Does it leak any fluids?
Even if it doesn't show signs of fluid leak, keep an eye out. I would regularly check the oil level and coolant levels until you are positive nothing is disappearing.
Do you have any pictures of the engine?
Looks like a nice car. No sunroof, interesting.
www.Only944.com Porsche parts, Only better, Only944
87 944 N/A 165,000 miles
84 944
Saved by God, because I could not.
Old 02-23-2008, 11:53 PM
J1NX3D's Avatar
hi , sorry i should have explained better. this guy loves this car and is selling im sure because hes getting too old to get in and out of it. he drives it on sunny days and is keeps it garaged.
I checked out his garage when we went for a drive. the garage floor was well used but no drips or anything. i had a could look around the head and block for leaks and signs of cleaning up also.
heres some pics from his ad but no engine pics sorry:
my stepdad wrenches his '83 944 and used to track an '86 so will make sure im getting a safe deal and check it out also.
might be able to knock some $$ off for the clutch and waterpump though he was aware they were original when he was explaining its history.
I have 16" 930 fuchs with fresh rubber on my turbo so im planning on swapping the wheels over.
- 6 spd/LSD
Old 02-24-2008, 12:06 AM
hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
SWEET Car! Good luck with it! looks like a keeper! Like the Phone Dials!
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 02-28-2008, 05:21 PM
Custom User Title
Dave L's Avatar
I actually considered 2 944's that were this color, Its very unusual and very cool
Old 02-28-2008, 05:44 PM
Arizona_928's Avatar
that's a awsome color, it's currently what mine is =O.
I would check all the rubber parts, fuel lines, radiator hoses, ect.
dolor et pavor
Copyright
Old 02-28-2008, 07:23 PM
unindicted co-conspirator
looneybin's Avatar
Looks great, but they put the steering wheel on the wrong side
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 02-28-2008, 09:23 PM
88
buy the bloody car ! drive it for another300k and keep maintaince up have fun 1 good miles per gallonor and over 135 miles hour , get your groceries in back or two or three bales of hay or 200 lbs of feed what more could you ask for except excellent braking and unreal cornering and braking in stock form go for it !!
Old 03-01-2008, 07:23 PM
924RACR's Avatar
Very nice colour! My wife would love it...
Meantime, keep your eyes open for a 951 or 968 engine to swap into the 931, maybe?
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 03-02-2008, 10:49 AM
God I want one of those Euro front bumpers so bad.
Old 03-02-2008, 12:16 PM
Very NICE! right hand drive, euro bumpers, no sunroof.... although, I heard the ones with sunroof are a little stiffer on corners due to the rolled edges acting like "ruffles have ridges" any truth on that?
"porsche it's an institution"
Old 03-02-2008, 01:24 PM
J1NX3D's Avatar
hi guys, thanks for the comments, i bought it today! only thing my stepdad could fault it on is the original clutch would need to be changed with the next year or 2 and that it also needs adjustment- too much travel.
dont know but i've read that also, but i have also read that theres less weight up high... either way i like the lesser complication of not having one, my 931 doesnt have one either.
S2/968 engines are hard to come by down my way, but i am currently looking at a 2.7L 944 engine ( the RoW '89) but the guy is asking too much for it.
- 6 spd/LSD
Old 03-03-2008, 11:02 PM
J1NX3D's Avatar
hi guys, i bought it! Picked her up yesterday.
Done 100km in it so far and all is well. Took a few pics while I've been out and about:
- 6 spd/LSD
Old 03-07-2008, 12:54 AM
