fast924S's Avatar
Send a message via AIM to fast924S
Suspension help
Hey guys, Im looking at doing some suspension work to my 1987 924S, I found this kit over at ground control, what do you think, Not a bad deal?
http://www.ground-control-store.com/products/description.php/II=696/CA=159
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 03-14-2008, 02:54 PM
74goldtarga's Avatar
Those look good, having a Koni insert gives one peace-of-mind. I get the impression that the rear shocks are not coil over so you don't have rear ride height adjustment at the spring perches and you would have to do torsion bars but they don't show a photo. Did they mention anything about adjustability? Nice price though.
'74 911 Targa - Sold to the highest bidder
'87 944 Turbo - Fix for track addiction
'72 DeTomaso Pantera - Sold to the only real bidder
Old 03-14-2008, 03:23 PM
It looks like they are custom valved and thus not adjustable for rebound or compression. I don't think this would make a good full-race setup but I'm sure they would work well for DE/AX if you don't want to go 4 corner coil-over with double/triple adjust etc. which would be expected to cost more.
Old 03-14-2008, 03:27 PM
fast924S's Avatar
Yea I think it just comes with Koni rear shocks. It would be for a street light DE/AX setup, But mostly street. I can adjust rear ride high with the accentric. I dont really want to mess to much with the Torsion bars since I hear its a big pain. SO I figure why not try this setup. Seems like a very good price for what you get. SHould be good for the street/back roads ;-)
Old 03-14-2008, 06:03 PM
924RACR's Avatar
I'd want to know (explicitly stated in writing) that the rear shock is also custom-valved. Furthermore, what front spring rate does it come with, and what t-bar rate in the rear is it matched to? I see no indication that there's provision for a rear coilover setup; without this, you would either need to replace your torsion bars or be limited in just how much your front spring rate could be increased over stock without completely screwing up your car's balance.
It also doesn't seem like that fantastic of a deal to me. I mean, a hundred more and you can have the Bilstein Firehawk setup WITH rear coilovers, much better shocks, and ditch the adjustable camber plates (not needed right away, for a street car).
You might also cross-shop the 944 Spec suspension packages - more work to install, but you'd end up with a proven suspension package...
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 03-15-2008, 06:06 AM
924 Racr makes a good point, check out the spec class suspension packages paragon products sells, they include sway bars and look like a good bargain. http://www.*****************.com/product_p/944spec-4.htm
You could also buy some Porsche OEM M030 front struts with adjustable konis and ride height (from Pelican), surely a good and proven setup and probably not much more expensive, I agree you don't need the camber plates as you can set the front camber at the eccentric on the strut, the plates give you quick adjustability and stiffness you probably don't need for your application.
The bilstein firehawk kit, I believe, is similar to the ground control kit and does not appear to have rear ride height adjustment or coil overs
http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Code=944SUSFIREHAWK
The bilstein escort cup kit does however.
http://www.lindseyracing.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=LR&Category_Code=944SUSESCORT
Old 03-15-2008, 08:14 AM
924RACR's Avatar
Oh, whups, thanks for the correction - guess I was getting the Firehawk and Escort pics mixed up...
Vaughan Scott
http://www.924.org
Old 03-15-2008, 09:30 AM
fast924S's Avatar
WOW those firehawks are Freaking $11,000!!!!!!!
Old 03-15-2008, 01:09 PM
924RACR's Avatar
LOL! Somebody better tell Lindsey... I'm sure there's an extra "1" in there.
They actually price at $1700-ish.
Vaughan Scott
http://www.924.org
Old 03-15-2008, 04:59 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Where in the world did you see them for $11,000?????
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 03-16-2008, 11:40 AM
