brinks's Avatar
'89 S2 shift issue
Suddenly, the car tends to get stuck in 2nd and 3rd gear. Depressing the clutch disconnects the drive train and you are able to push the accelerator and rev the engine, but it is physically difficult to move the shift linkage to get it out of gear or to change gears. Once out of gear it will shift into another gear. There are no issues from a stop shifting into either reverse or first. Any suggestions?
Old 03-07-2008, 05:30 PM
Kiwi944s2's Avatar
My 91 S2 started doing this in November. The end result was the bearings in the gearbox were shot and I have had to have the gearbox rebuilt. In addition when fitting the new gearbox last week turns out the clutch is all but shot as well so this is currently being rebuilt as well. Should have in back next week but sounds like the same problem that you have.
Old 03-07-2008, 05:34 PM
In the Fires of Hell.....
kdjones2000's Avatar
That one sounds pretty unusual.
I would first start by looking at your shifting linkage, both at the shifter and back at the transmission.
The post connecting the shifter handle to the rod gets worn, making shifts loose until it completely disengages.
There is also a bolt that can get loose at the transmission that might be your problem.
If this all checks out, then it sounds like you have something going on inside the tranny, maybe synchros.
Good luck with it,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-07-2008, 05:35 PM
brinks's Avatar
How many miles were on your clutch?
Old 03-07-2008, 06:05 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Good luck with it,
Keith
This is the route I would take as well. If the linkage isn't going back to the positions it's suppose to, this problem will come up.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 03-08-2008, 03:50 AM
Kiwi944s2's Avatar
70,000 miles on the clutch. the rubber centre was all but disintegrated but somehow although in a million bits the bits must have been holding hands because it still formed a perfect circle. Roll on the spring centred replacement.
Old 03-08-2008, 04:01 PM
brinks's Avatar
I just got the car back from the shop. The rubber disc let go in the clutch. There are no issues with the transmission, thank goodness. The shop was pretty good. They did the change out in 10 hours.
Old 03-15-2008, 01:36 PM
