I Am Getting Fuel In My Crankcase After Replacing Throttle Positing Sensor Any Suggestions On How Gas Got In Oil
It's dumping way too much gas in the cylinders and it's running past the rings. Be careful you could hydrolock your car maybe even bend a rod. Check the new TPS sensor carefully to make sure you have the proper voltage when you are suppose to have it. If you need instructions on how to test that, let us know.
Tom 1990 944S2 Cabriolet 2002 Chevy Silverado 2500HD 2003 Maroon Ford F350 dually |
your average wrencher...
bend a rod, these are over-head cam cars.....no rods, just tappets..........lol. yes check the voltage from shut to wide open, should be in a certain range...you just have to find yours
1982 931 *project* 1986 951 Garrett turbo, Rogue Tuned (sold )1987 944S chipped, konis, rollbar (traded) 1979 924 total rebuild and blueprinted (sold) |
