Mountain Road Maniac
ColoradoSteve's Avatar
Altitude and Compression
Just did a compression test and all four cylinders said 120. I can't find anything to tell me what the compression should be, but I thought it ought to be 150 or higher? I'm at an altitude of 8300', is that a factor? The car runs great and doesn't burn any oil so I'm not concerned, just curious.
'83 944
Old 05-13-2008, 08:36 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
correct, you will have less pressure in the cylinders as a result of being at that altitude. the simple explanation is that there are less molecules of air to compress per volume, so you're going to see lower numbers.
ISA (International Standard Atmosphere) is 29.92 inches of mercury (or 1013.2 millibars) at 15 degrees celcius/59 farenheit at sea level. there's gotta be a reference somewhere that'll tell you approximately what ratio you should be seeing at that altitude... but 120 sounds like it should be about normal to me... the important thing is that your cylinders are even in compression, which they are!
iirc at 10000 ft the millibar level is approximately 700 or so...
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 05-13-2008, 10:12 PM
ASE Master
alfadoc's Avatar
In Denver we add 20% to compression test and vacuum readings in order to equal sea level. We also subtract 20% from published horsepower figures. :-(
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 05-14-2008, 10:28 AM
