overheated
Tonight i was working on my car, and letting her run for a little bit. All of a sudden i see some smoke coming from the hood. I quickly turn the car off, put the key in Pos. 2, and run the heater to cool her down faster. Later I noticed, that when the car is running, the fans don't work unless the heater/AC is on. AC/heater are the same in my car, both hot as hel. I'M thinking it is the relay, but haven't had much time to look into it. Any thoughts?
Steve- If you havent looked, look- www.clarks-garage.com 87 951 red- Maria (current) 84 944 white- Percilla (current DD) 85.5 944 red- Pinta (past) 87 924S red- Nina (past) |
when its hot carfully feel the radiator hoses, if they arent HOT, then possible stuck closed thermostat. BUT FIRST: on the radiator fan switch touch together or jump the 2 wires together with the car running if the fan does come on the you should replace the switch. Be carefull when troubleshooting, you dont want to go past 3/4 on the temp, HG's dont like that.
83 944....bye bye 85.5 euro spec 944, 5sp (she's gone.... ![]() 74 914...hasta LA Vista baby 87 924s....don't let the door hit ya 68 912.......see ya! |
Trying to work for parts!
+1 on what Earl said. Test the switch first. And dont let it over heat. Much better to have a $40 fix instead of a $1200 head gasket job.
86 Metallic Grey 85.5 Metallic graphite - Gone |
