-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Rear Whl bearings done but new Problem (http://forums.pelicanparts.com/showthread.php?t=413457)
jackd2001 06-07-2008 12:20 PM
Thanks for the help on the wheel bearing replacement...
After replaceing the wheel bearing I was able to detect a noise and some play in the Tx where the CV shaft mounts. I think I have found the parts diagrams, but I am not sure how to procede with the repair.
Are there bearings that are replaceable without removing the Tx?
Should I do this myself (reasonably good and thorough)?
Any special tools required
1983 944 5spd
Thanks in advance
944 Ecology 06-07-2008 01:38 PM
Do not replace any of the bearings in your transaxle.
This is not a job for the faint of heart. You have to measure, shim, remeasure and reshim the differential or you will destroy your transaxle.
Have a competent transmission specialist do it for you.
