-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Guage Cluster (http://forums.pelicanparts.com/showthread.php?t=421422)
Its_Scott 07-23-2008 01:21 AM
Gauge Cluster
Is there any way I can separate the transparent piece from the actual gauge cluster. It's stuck pretty tight! Is it glued on or you can pry it apart? Thanks!
looneybin 07-23-2008 09:19 AM
I think it's glued on, but if you remove the gauges from the housing, you can CAREFULLY use a dremel tool & cut the pieces apart
phoenix_iii 07-23-2008 09:51 AM
Dremel and 'Careful' = good luck....
SmileWavy
fbgh2o 07-24-2008 09:39 AM
It can be done with a sharp exacto knife and very gentle prying. Mine was not glued all the way around - rather it was glued at different points - similar in concept to stitch welding.
Its_Scott 07-25-2008 03:16 AM
Thanks for the info. So after disassembling the unit, how would you guys put it back together?
looneybin 07-25-2008 08:20 AM
Try a couple of dabs of plastic model glue
fbgh2o 07-25-2008 02:25 PM
I think that I used silicone (or was it super glue gel). Both would work.
