Gauge Cluster
Is there any way I can separate the transparent piece from the actual gauge cluster. It's stuck pretty tight! Is it glued on or you can pry it apart? Thanks!
Stock 89' 951
Old 07-23-2008, 01:21 AM
unindicted co-conspirator
looneybin's Avatar
I think it's glued on, but if you remove the gauges from the housing, you can CAREFULLY use a dremel tool & cut the pieces apart
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 07-23-2008, 09:19 AM
Quality
phoenix_iii's Avatar
Dremel and 'Careful' = good luck....
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 07-23-2008, 09:51 AM
In over my head
It can be done with a sharp exacto knife and very gentle prying. Mine was not glued all the way around - rather it was glued at different points - similar in concept to stitch welding.
Fergus
86 951 Graphite Metallic
86 944 n/a Garnett Red Metallic (SOLD!)
74.5 Triumph TR6 (restoration project)
05 Subaru Legacy (winter car)
Old 07-24-2008, 09:39 AM
Thanks for the info. So after disassembling the unit, how would you guys put it back together?
Stock 89' 951
Old 07-25-2008, 03:16 AM
looneybin's Avatar
Try a couple of dabs of plastic model glue
Old 07-25-2008, 08:20 AM
In over my head
I think that I used silicone (or was it super glue gel). Both would work.
Fergus
Old 07-25-2008, 02:25 PM
