PorscheJeff95
front struts replace
before I tear into replacing these front struts(I'll probably just put new inserts in them)...are there any parts in there that typically will also need replacing????....rubber stop, concave washer, sealing ring, brg flange, strut mount,.....etc. the car is an '83 944..with only 66000 miles...probably never been changed...thanks
Old 09-02-2008, 06:18 PM
Custom User Title
Dave L's Avatar
there were some foam type of gaskets between the strut and the body that will deteriorate, Bump stops.
thats all I can think of.
Old 09-02-2008, 06:25 PM
Nobody Special
If the strut mounts are tight and nothing looks chewed up just do the inserts. It's very easy on an 83. I did mine on the car without removing the strut, no spring compressors, or messing up the alignment. Others will say it 's unsafe to use the weight of the car to compress the springs but many, many people do it this way without any issues I know of. Takes less than 20 minutes a side. Loosen the cap at the top of the strut tube first before loosening the top nut on the shaft.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 09-02-2008, 07:52 PM
Misunderstood User
In addition to what has been said, take a look at the top bearings.
There have been many posts with pictures on how to, either by leaving them in the car or taking them out completly. Either is fine. I took mine out completly. I went a little nuts, cleaned everything up, painted, replaced what I needed and went with new springs too.
Jim
1983 944n/a
2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway
Old 09-03-2008, 05:05 AM
Toofah King Bad
Rasta Monsta's Avatar
+1 to 2tight. . .safer than a compressor, IMO.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-03-2008, 06:39 AM
Politically Incorrect
onZedge's Avatar
follow the link below my sig. lots of pictures
sorry for all lower case, but i was afraid i might offend somebody if i used any capital letters...
Edek
'87 924S
'91 535i
Old 09-04-2008, 02:13 PM
