Need to know..Boxter rim offset spacers on 1983 944
i know that this topic has been through the washer..BUT, what spacers should i use for my car (1983 944) using the boxter twists? they are 17' 225 Front and 255 rear???
thanks. I need to get the spacers right away since I already sold my 15" fuchs.
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Trying to work for parts!
the boxster wheels should be 52 offset, so you will need 20mm spacers on all 4 wheels.
86 Metallic Grey 85.5 Metallic graphite - Gone |
thanks!!!!!
Just remember, it's simple math. Subtract the offset your going with from the offset you have and then you get the spacer amount.
so 1 inch spacers (25mm) should do???
Non Compos Mentis
1" spacers work fine. I bought a pair right here at Pelican, and they work just great.
thanks!!! i can get some 1 and a quarter inch spacers on ebay (concentric) cheap. i suppose if one inch will do so will one and a quarter??
ernest
You HAVE to use HUBCENTERIC spacers. Concentric wont fit over the lip on the hub.
and 1 1/4" will push them out too far and you will end up rubbing/slicing your wheel.
Non Compos Mentis
Porsche uses a unique lug pattern (5 x 130mm) that no other manufacturer uses. The spacers must be Porsche specific, or they will not work.
