1984 porsche 944 na
Throttle response cam
Ok nothing new to you veterans but if someone here has an 8 valve 944 and wants to feel like they are driving a different car go and BUY it NOW!!! Best 30 bucks I have spent so far on my car....
What exactly does it do? Change the throttle curve? and where does it go?
Well it changes the ratio of pedal position to throttle body position to a direct 1:1.
The stock cam starts out with a ratio of more pedal to less throttle opening, therefore making it very easy to apply just enough gas to start out and be smooth when releasing the clutch. When starting out with the aftermarket cam, its hard to give it that same amount of throttle since you move the pedal a little and it moves the throttle much more than normal, it's hard to explain. To make a long story short, it pretty much sucks. |
No way The throttle response cam is sweet. I like the 1 to 1 feel, It makes the car feel faster, You just have to know how to drive your car and get use to it
1986 951, Stock for now. ]87 924S Gaurds red- SOLD after 11 years of ownership |
I hated the feel of the original cam since I was used to cams with a 1:1 ratio. So I got used to the original cam but still hated it. Then I switched to the aftermarket cam and loved it in the beginning. It does make the car seem faster and more responsive. It was nice but I still had trouble being smooth. Had it on for probably a month or so. Went back to the original cam and absolutely love it over the aftermarket one.
It's just not for everyone I guess. It made my pedal feel very stiff. |
smooth is fast
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme '88 951S - zermatt silber/black - staying stock. purchased in 11-2006 '84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001 2021 Tesla Y - to get me to work |
I'll take the middle ground. I always thought the stock cam was too slow to react, so I bought the "response" cam. When I found that to be too abrupt and harder to modulate, I decided to split the difference. I took the stock cam and cut about half of the finger off of it with a hacksaw. Then I radiused the edge with a small file so it wouldn't wear on the cable. I polished it up, bolted it back on, adjusted the cable a bit, and drove away. I'm pleased with it, and at a total cost of $0, it was worth every penny.
Dan Former owner of: '88 924LE (Luddite Edition) manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5 torsions, 931 valance and header panels, 6X16 Fuchs, lowered, etc, etc. |
I have had the aftermarket cam for 3 years now and love every second of it. But then again I am less concerned about how smooth I am taking off while leaving the retirement home for a trip up to the waffle house.
For what I do with my car anyway, the direct 1:1 response is extremely helpful, since there is so much abrupt throttle position changes going on while drifting.
- Elliott Grafton - 944Barn Last edited by drift a 944; 09-10-2008 at 11:15 PM.. |
Misunderstood User
I did not want to spend $30 on the aftermarket throttle cam so I modified the stock cam. I played with the lever length at the end of the stock cam until I found something to my liking. I probably cut off about 75% of the lever. Works very well. It is not stock and it is not a circle. I don't have a heavy feeling pedal and it is smooth.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Trying to work for parts!
I tried it on my daily driver. Absolutely horrible. For a track car or an autox car it would be great. but for a car that has to drive in rush hour traffic I'll stick with stock.
86 Metallic Grey 85.5 Metallic graphite - Gone |
1984 porsche 944 na
There must be something wrong with my car... It feels and accelerates now like I think it should..It does not shift awkward and feels smooth..If it was broke I say this fixed it
unindicted co-conspirator
I have to agree.
I have had a t-cam on my car since i bought the car, & i wouldn't change it back. It's great the way it is with the cam
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
Toofah King Bad
Another vote in favor. Makes the car snappier, and I have no problems driving in traffic. . .must be the 931 training.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Greasy Member
I think it depends on how/what you are used to driving.
If you are a "track" driver, the response cam make the car "feel" like it is right there when you get on the throttle. If you are a DD/commuter, the stock cam is better in traffic and around town. Personally, having been behind the wheel of alot of "performance" vehicles, I like the feel of the round cam. As a side note, if you have a performance chip there certainly is more appeal to the round cam, IMO. -Nick
Owner: Bennington Motorsports www.benms.com Sponsor for Midwest Region 944-SPEC racing series -When was your timing belt changed or tensioned?? -Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP. |
So which one is standard? My car came with a round throttle but my roommate's came with one shaped like a teardrop.
1984 porsche 944 na
standard has an arm built on it.. Just round is aftermarket
Yes teardrop is oem and round is aftermarket.
I was under the impression it was the other way around the whole time! So, for a daily driver, it's personal preference whether or not the 1:1 cam is good or not. I learned to drive on the 1:1 (learning to drive standard for the first time!) so honestly I have no idea what should feel 'better'.
