Porsche Crest 944 strut mount issues
Hey all, on my '83 944 i have a knock in my front right strut, i've noticed that th e upper mount itself sits higher and looks looser than the opposing one. From what I've read, the likely culprit is a rubber spacer. I've had trouble finding this piece and was wondering if there may be an uprated part or better way of fixing this. I've found Solid metal upper strut mounts on 944online.com would these solve my problem? any response will be helpful, thanks.
Old 09-20-2008, 08:14 AM
Toofah King Bad
Rasta Monsta's Avatar
You mean THIS?
Might as well do both, and might as well also change out your strut inserts while you have it apart. . .I doubt the noise is coming from the rubber mount.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-20-2008, 10:10 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
I think he means the little piece of foam they put around it where the mount attaches to the body. I've never replaced this and doubt highly that it's your problem.
Have you tried torquing down the mount?
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 09-21-2008, 10:05 AM
No I have not tried torquing it down yet, i couldnt do it by hand, and havent tried with an impact wrench yet. is this safe to do? willl this adversely affect handling?
Old 09-26-2008, 03:44 PM
Toofah King Bad
What exactly are you contemplating hitting with an air gun? I don't suppose you could post a pic of what the hell you are talking about.
Old 09-26-2008, 04:17 PM
Tags
944 , knock , mount , strut , suspension
