Guage Cluster Removal Help
I'm trying to remove the guage cluster on my 944 both so I can fix the odometer and clean up some connections to hopefully fix my temp guage issue. So I assume the two screws I need to remove are towards the top of the cluster between those two circular plastic pieces. Problem is, I can't get those little plastic pieces out so I can remove the screws. Any tips on getting them out?
83 944 NA - daily driver
Old 11-23-2008, 02:30 PM
Hi, those 2 piece are for decoration only. You will see 2 screws on top just above the gauge bezel of left and far right gauge that point strait up. If you can't fix your odometer problem I have a working speedo that is available.
Old 11-23-2008, 03:09 PM
