I need help with thermostat, STAT
Alright guy's and some gal's, I think I made a minor but stupid mistake when I installed my thermostat. I recently replaced my W/P and when I put my t-stat in
I put it in the following order, thermostat, O-ring then cir-clip. If anyone could please post the correct diagram or the proper order of the install I would appreciate it. Thanks in advance. Also it is the new style pump with block off plate.
Old 12-30-2008, 07:22 AM
GostRidr's Avatar
I haven't done this yet but it sounds like you got it right according to www.Clarks-garage.com -thermostat with O ring and spacer and then the snap ring. I'm thinking there might be a diagram right here when you pull up one of the parts.
Good luck!
peter
1991 944S2 Cab, Crystal Silver Metallic "Platinum Banshee"
1987 944S Alpine White, Ice Shark Lights "Desert Ghost"
2015 Charger R/T Road & Track
Old 12-30-2008, 08:50 AM
Schumi's Avatar
As per the parts diagrammes:
Looks like you have described it correctly.
M
Old 12-30-2008, 11:56 AM
Thank you ,I don't think I put in the spacer
Old 12-30-2008, 12:37 PM
it depends, my A/M waterpump came only with a (ill-fitting) gasket that wraps around the thermostat. no 'spacer'. Same as the pump and 'stat that i removed. i had to use a driver with a light mallet to get it to seat properly in the channel. what a stupid design all around.
Old 12-30-2008, 03:19 PM
Greasy Member
many944s's Avatar
The o-ring should have had a "slit" around the inside edge, which allows the o-ring to be "attached" to the edge of the t-stat. There are actually 2 o-rings available. The determining factor is the spacing between the shoulder in the water pump and the snap ring groove. I have seen MANY motors where the spacer ring wasn't even used.
For what it's worth.
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 12-30-2008, 07:03 PM
Not sure which yr/model yours is. I agree with many944. Recently did my '88 951, it had no spacer and the gasket fit AROUND the t stat. I tried it your way first and it just didn't fit right.
Look at your gasket closely and see if has a groove in it.
Good luck,
Bruce
Bruce P.
2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 12-30-2008, 08:05 PM
944Spec_bound's Avatar
ya, if I remember right I just used the seal that wraps around the edge of the stat and the snap ring fit snug up against it.
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy
My Website:
http://www.TrackPics4Less.com
Old 12-30-2008, 08:25 PM
