-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   dual carberator conversion 2.5 NA ? (http://forums.pelicanparts.com/showthread.php?t=449613)
bobe 01-04-2009 11:39 AM
I recently saw a 944 2.5 NA with dual webber side draft carberators. Has anyone performed this conversion, or direct me to someone who has some knowledge in this matter. It's got to be cheaper than the V8 conversion and a lot less B.S.
pdx944 01-04-2009 12:27 PM
Why? Its not an upgrade...
HondaDustR 01-04-2009 03:30 PM
Got proof it's not an upgrade?
It certainly could work quite well if implemented and tuned correctly. It would be kind of like ITB's, with the relatively easy intake tuning possibilities that go along with that type of setup, and without all the hassle of a custom and expensive engine management system. It would just need a little more tinkering when the weather changes and stuff like that. Combine that with a high flow cam and exhaust, and it could be a pretty sick setup, especially if it was a track car. :D
speedracing944 01-04-2009 03:52 PM
One of the options I was going to do with my S engine was ITB from a GSXR1300
Speedy:)
thoen 01-04-2009 04:06 PM
what is ITB?
speedracing944 01-04-2009 04:18 PM
Individual throttle bodies
Speedy:)
halik 01-04-2009 08:11 PM
Originally Posted by AZ_porschekid (Post 4397580)
i think i saw that one, it said it made over 200 hp too. "like 205 HP"
Where exactly would that extra 60hp come from?
Arizona_928 01-04-2009 08:20 PM
bigger valves, good tuning, and a aggressive cam..?
just a guess
bobe 01-05-2009 02:55 AM
carbs
I'm a little bored with the stock performance and can't afford a 911 . I sold an older vette with a 400 hp motor. Lets just say I miss the power. The 944 out handles that car hands down, but I would like some more power. Are there any websites that have info on the carberator conversion. That would probaly be the most economical way to go. http://forums.pelicanparts.com/uploa...1231152895.jpg
914efi 01-05-2009 04:31 AM
Since you have to make significant engine mods for the extra power and you already have all of the FI stuff, it would be much cheaper to do your mods, buy a megasquirt computer and tune away. Assuming this is a street car the ITB setup is overkill. Any HP gains will be at the expense of driveability anyway.
Sorry to be a killjoy, no replacement for displacement.
Dantilla 01-05-2009 05:49 AM
If you're looking for performance, it's time for a 951.
If you're looking for a project, carbs on a 944 could be fun.
bearone2 01-05-2009 08:25 AM
why reinvent the wheel.
fi made for better starting, near elimination of hot start issues of fuel vaporizing after stopping for the 5 min post office/store run and ez to modify for higher hp gains.
i agree, 200hp with just the webbers is a joke.
petrolhead611 01-05-2009 08:53 AM
bike carbs conversion
Many people replaced 80's fuel injection on motors from Peugeot, Lotus,Ford, Vauxhall etc,with twin Weber DCOE'S in the 90's for racing use; then progressed to bike carbs(BOGG BROTHERS in North Yorkshire, England, will probably still do this for you including handmade inlet manifold),but now the Megasquirt has arrived for the Noughties..
HondaDustR 01-05-2009 05:17 PM
Yeah, some Keihin flat slide race carbs from a motorcycle would be awesome. The advantage of carbs would be that it's relatively a piece of cake to change fuel delivery to accomodate mods. With the stock FI, forget it...Completely redoing the engine management...expen$ive and complicated. Stock FI's good when it works, but it's so darn hard to change stuff if you want to. You either trust someone else's idea of what a good tune is and pay a couple hundred $ for their chip, or you get software and all the stuff, and learn how to tune custom chi[ps. Besides, there are many of us that just enjoy the idea of custom work, even if it's not "worth it". ANYBODY can go on ebay and find a turbo 944. It's not just about fast. Cool engineering projects FTW!
I like the idea of something you can't buy off the shelf that makes people just go "WOW!" even if it only gains 20 hp. Custom FI would be awesome, and so would a rack of carbs. To each his own...but people have been driving and racing on carbs for decades past and they do work. :D
JonA 01-06-2009 05:29 AM
You going to be able to pass emissions with carbs?
Jon
bearone2 01-06-2009 08:52 AM
that's true but fi was generally replaced with webbers, su's because the fi had problems and was too expensive to fix.
i replaced stombergs on an old volvo with su's for mileage, starting and drivability and there were a ton of manifolds/su's available from older cars so it was an ez swap.
porschenewb 01-06-2009 05:37 PM
http://cgi.ebay.com/ebaymotors/Cars-Trucks___1985-2-PORSCHE-944-TRACK-CAR_W0QQitemZ230317474197QQddnZCarsQ20Q26Q20Trucks QQddiZ2282QQcmdZViewItemQQptZUS_Cars_Trucks?hash=i tem230317474197&_trksid=p4506.c0.m245&_trkparms=65 %3A7|39%3A1|240%3A1318 check out this guys car
HondaDustR 01-06-2009 07:38 PM
:eek::eek::eek:
I knew it was possible to hit 200hp from the 8v 2.5! Probably noy cheaply... That project would be to die for, though!
Arizona_928 01-06-2009 08:20 PM
I knew it! but look at the mods, the whole 9 yards.
running_cold924 01-07-2009 05:32 PM
http://forums.pelicanparts.com/uploa...1231378281.jpg
http://forums.pelicanparts.com/uploa...1231378318.jpg
my little 924 liked them.....but also liked the fuel at 13mpgs..........but it was fun!
