85.5 944 Radiator Fan Question
I just removed my A/C unit and I wanted to utilize both fan motors for the purpose of cooling the engine. Couple of questions:
1. Has anyone else done this and is it recommended?
2. How were the two fans hooked up?
3. If I'm standing in front of the radiator, which fan is used for the A/C unit?
Thanks,
Bob
Old 03-21-2009, 04:05 PM
Proprietoristicly Refined
John_AZ's Avatar
Hi Bob,
I'll just comment on Q1.
The fans, thermostat, fan switch in radiator and the coolant temp sender in the block are related. The car needs to get to a specific temp to be efficient. The coolant temp sender in the block sends a signal to the DME computer at proper temp. I am sure hooking up both fans is completely possible and should keep engine temp down. I do not know what would happen to performance and mileage.
When you turn off the switch and leave the car, the fan(s) say on until the radiator fan switch gets to the low temp.
If both fans are connected, the battery will discharge. You may have to compensate with a different radiator fan switch temp to avoid the battery from dying completely.
GL
John_AZ
Old 03-21-2009, 06:15 PM
Mountain Road Maniac
ColoradoSteve's Avatar
Don't know about the wiring on the switches, but what happens now when you turn the AC on? Maybe that's all you have to do to start the fan?
'83 944
'87 951- SOLD!
Old 03-22-2009, 04:55 PM
