'87 Porsche 944
87 944 engine noise???
My car seems to make a loud ticking noise when the car is in idle as well as in motion. It seems to get louder and faster as the rpm goes up.
Any advice on what it could be and how to correct it?
Old 04-02-2009, 03:48 PM
dkbautosports.com
962porsche's Avatar
i would say hydraulic lifters ????? if so ? its not good !!!! depending on the severity of the lifters bleeding down it may damage your cam lobes if you keep driving it that way .
Old 04-02-2009, 05:14 PM
Proprietoristicly Refined
John_AZ's Avatar
The lifters do tap but the sound should deminish with oil pressure increase. You could try some SeaFoam for a few miles and then change the oil and filter. Search for past users and results. To replace the lifters, remove the top cam. Try to find "good" used as the new INA are expensive and may fail. You can test each lifter once removed. Post for more information.
If the noise is not coming from the top of the engine, it may be the rod bearings. After you use SeaFoam, look carefully at the oil and check for shavings of metal. Try to filter your old oil with cheese cloth or an old pair of nylons. Rod bearings should be changed at around 110 to 125K miles.
Another interesting link:
http://forums.rennlist.com/rennforums/924-931-944-951-968-forum/350563-knocking-from-cam-tower.html
GL
John_AZ
1988 924S + 1987 924S
Old 04-02-2009, 06:01 PM
Send a message via AIM to Icey1174
Are you sure the noise is not the fuel injectors? They are VERY noisy!
John
'87 944 N/A (first Porsche)
'95 E-350 Diesel
'03 S-Type Jag 3.0
'03 Taurus SES
'06 Eddie Bauer Explorer
RIP SoCal
Old 04-02-2009, 06:26 PM
