-   Porsche 924/944/968 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=10)
-   -   Immutable Laws of mechanics (http://forums.pelicanparts.com/showthread.php?t=468174)
Sphinx 04-10-2009 09:45 PM
34. A project takes you 5 hours, then you learn how to do it the easy way in 2.
35. If you work on your car in the driveway, it's always a good time to rain.
36. Your repair, in turn, causes another problem.
37. The jobs you think will go quickly, takes all day.
38. The AAA girl recognizes your voice.
39. Failure of the cheap part creates an expensive repair.
40. The wrench or socket you will need the most is the one you don't have.
41. After you break the torque on a stubborn bolt you use a "band-aid"; which consists of a dirty rag wrapped in duck tape.
Ctan 04-11-2009 07:03 AM
42. The tightest bolt will be covered in grease, rounded off and surrounded by sharp edges.
callmethewander 04-11-2009 07:59 AM
43. When a bunch of morons work on a car that requires specific technical knowledge and advanced mechanical ability, a list like this results.
( sorry, I like dark humor. I am just joking of course, This forum has been a treasure chest of information and help to me. Much thanks to you all)
jmd_forest 04-12-2009 07:02 AM
34: It will cost more than you think and take twice as long.
jmd_forest
JAXTURBO 04-12-2009 01:05 PM
35: Don't bother counting the number of bolts you removed, there will always be 1 or 2 left over. Save it for the next unrelated project since you'll need it then.
mistertate 04-12-2009 01:25 PM
36: Timing belts only break for people who believe 944s are unreliable
blepkowski 04-12-2009 02:47 PM
44. You know you have older car experience when a can of worms is nothing compared to the can of angry bees you just opened!
slow944s 04-12-2009 07:27 PM
Hi everybody!! First post and I always like to read these kinds of "Murphy's Laws."
Here are acouple you may not have heard:
Murphy's third minor law states: If things seem to be going well it's a dilusion.
When measuring resistance, all tolerances will go to one end.
Kirchof's Law States that Murphy Was An Optimist.
Thanks for letting me play along.
toolboy62 04-13-2009 08:00 AM
45. You will think that you can do whatever it is you need to do to your car without touching the headers, and therefore will attempt the repair with the engine warm. You will be wrong.
JoshB 04-13-2009 10:20 AM
46. Whenever you finish your repair no matter how small there will be an extra bolt or nut or washer left. Wondering if it was important will briefly cause concern but as long as the cars starts and runs you will forget about it mostly....
Pops944 04-13-2009 05:25 PM
47. No matter how well you plan to clean every part as you start to work on your car and keep yourself clean, by the end of the day you have more grease and oil on yourself than in the car.
halik 04-13-2009 05:38 PM
48. If you can see the bolt, you can't get to it. Conversely if you can get to to the bolt, you can't see it.
Mankato944 04-13-2009 06:07 PM
If you try to fix that tiny scratch, you will make it worse.
Moneyguy1 04-14-2009 09:35 AM
My dear departed bride (who was my "eyes" during a lot of various P-car repairs) noted the following concerning Porsche repairs:
"If you can see it, you can't reach it. If you can reach it, you can't see it" Hence why she was my eyes.
cwiert 04-14-2009 10:11 AM
51. You will trip over a tool or a part everyday for 364 days until the day you need it, when it's suddenly no where to be found.
exitwound 04-14-2009 10:36 AM
52. When all else fails, your car will be one of a transition year. Manuals and online procedures will not apply.
53. Most "Porsche Special Tools" can be adequately substituted using an SAE flare wrench, a piece of steel pipe, a paper clip and a grinding wheel.
Smoker324 04-14-2009 11:36 AM
54. When under the car and you need a 13 mm 3/8 inch drive 6pt socket you will reach into the tool bag and get, in this order: a 13 mm 1/4in, 12 mm, 14mm, 13mm 12 point deep, 16mm, a 3/8 to 1/2in ext, a second 13mm 1/4in drive, a 12mm 6pt and finally -- a 13mm 3/8 drive 6pt socket with a rusted nut stuck inside it.
jerry920 04-15-2009 06:55 AM
55. The only location to hang the work light will either:
a. Shine it directly in your eyes or
b. Point it in the opposite direction.
emoore924 04-15-2009 10:01 AM
56. No matter what, if you take your original estimate, then double and add 10%, you might be close...
...except for that rusted bolt, which you just broke off.
944 boy 04-15-2009 10:07 AM
57. It's not the size of the bolt in the fight, it's the size of the fight in the bolt (or nut)
58. A large vitally important bolt holding the suspension on the car will be loose, a small tiny bolt holding a part on along with 10 other bolts will be frozen solid and break flush requiring hours of work on an otherwise trivial task.
