Addicted to Racing
edbaus's Avatar
DME relay is flickering
So, My 86 944 is having an issue.
It starts and runs great. It will not drive very well.
Even as it sits and idles it seems to turn on and off. Just for a moment. If you put your hand on the DME relay you can feel it turn on and off.
I have swapped out DMEs, DME relays, air flow sensor, speed and reference sensor, checked the ignition. Still have the issue.
I am looking for the next thing to try.
Ed
Check out the parts for sale:
http://www.demonspeedmotorsports.com
PCA National & NASA Instructor, NASA GTS & PCA GT Class Racer.
See my list of current cars in my garage.
Old 05-02-2009, 06:48 PM
TibetanT's Avatar
Hey Ed:
I didn't know you had a 944?
My thoughts right now are, you may have a bad DME relay.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 05-02-2009, 08:18 PM
tnporsche's Avatar
I elliminated the dme relay!
Well sortof, I coverted it to a much more reliable 40 amp SPST available at any autozone. ( $5.00! ) If your interested I can post how.
Lowell
1988 944 Red Project car (Now daily driver, Daughter's to school ride)
1983 944 Grey NEW Project car
http://www.pelicanparts.com/gallery/tnporsche
Old 05-02-2009, 08:32 PM
Addicted to Racing
edbaus's Avatar
Yes. I have it to go 944Cup racing. All set except for this problem.
I used a jumper wire and jumped it out. Still have the same problem. My understanding is that the DME actually powers the relay, not the other way around.
Ed
Old 05-03-2009, 01:15 AM
tnporsche's Avatar
Ed
If the jumper did not help, then yes eliminating that dog! of a relay wont help. :-)
Although even when new, I question how good that relay is? I went through 3 shutdowns about 12 or more no starts. Usally when it was dog a%$ cold , or hot. I would put the jumper wire and it would start or go. I started using backup dme relays. I had one used and one new, rotating them when it failed. It was Interesting I noticed if I put the original one back in, then it would work again also. I have been running on the auto-zone relay for about six months. Not a single failure yet, Ha !take that bad designed relay!
So if your sure its not the relay how about.
Have you swapped the dme out?
How about ref sensors and connections?
Grounds?
Lowell
Old 05-03-2009, 06:16 AM
rattlesnakeracing
alantica's Avatar
Porsche Crest Vacuum leakage?
Ed
edbaus,
I would suspect a vacuum leakage in the fuel injection system, intake manifold or vacuum hoses. You have covered all of the electronics plus the AFS. Have you checked the spark plugs? Are they fouled?
87 Charcoal Metallic 944{Proj} 88 White Pearl 944{Daily Driver}
87 Silver Mazda RX-7{210K no rbld} 87 Charcoal Mazda RX-7 GSL{Proj} 88 Gold Met RX-7{Parts} 89 Midnight Black Mazda RX-7 Conv.{Proj}
87 Intl. Scout II{Proj} 99.5 Nissan Pathfinder LE {Daily Driver}
USAF (Ret) GO Blue! - - RattlesnakeRacing - Don't Tread on Me!
Old 05-03-2009, 02:01 PM
Check your ignition switch.
Good luck, George Beuselinck
Old 05-03-2009, 03:33 PM
Addicted to Racing
edbaus's Avatar
AND THE WINNER IS......
The ground.
Despite checking, cleaning, and fussing with it, when I put a jumper cable between the ground, the chassis and the motor the problem disappeared.
Now if only I can get that reference sensor bolt that I dropped into the clutch inspection hole back...
Ed
Old 05-04-2009, 12:13 AM
Addicted to Racing
edbaus's Avatar
OK,
New answer. The ground was not it.
Turned out that the car had solid core wires causing an RF problem with the speed sensor. New one on me.
Ed
Old 05-11-2009, 11:09 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
Hey Ed,
Could you please explain what you mean by a solid core wire and how the reference got the wire? Just trying to understand....and how did you figure that out?
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 05-11-2009, 02:36 PM
Addicted to Racing
edbaus's Avatar
My nephew can explain it better, but solid core wires, although do a good job of transmitting spark energy, also emit a HUGE amount of RF noise. Enough noise that even the well shielded speed and ref sensors can get interfered with.
Solid core wires should only be used with magneto or points style ignition systems. Nothing with a brain.
Old 05-11-2009, 02:55 PM
Are you saying solid core ignition wires? Sorry for being confused here.
Tom
Old 05-11-2009, 03:05 PM
Addicted to Racing
edbaus's Avatar
Yes, the wires that run from the distributor to the spark plugs.
Ed
Old 05-11-2009, 06:10 PM
