Factory Alarm
so does anyone have a clue as to how the factory alarm operated? i have the cliffird alarm that came with the car in 83'. any input would be nice, im sure i will install a new alarm with remote door lock and start but would still like to figure this out
Old 05-17-2009, 12:18 AM
TibetanT's Avatar
Hello There:
I have the Clifford alarm system in my 1987 944n/a, so I am not sure if this will be applicable to your application.
However, basically the alarm system is armed via a switch located in the driver's side door, behind the latch. When armed, via key, the alarm module which is located near the ECU/DME brain under the passenger side floor board, will sense any intrusion. For example, my car has a switch located in the engine compartment, driver's side, near the fuse box on the frame. If the engine hood is opened, the switch is open and circuit then is hot, the alarm module cuts power to the ignition switch via the DME relay, which also cuts power to the fuel pump and sends power to an alarm horn which is very loud! The car is then in a mode where it will NOT start, until of course the switch is de-activated via the key.
Same process if someone tries to open a door or the hatch in the rear.
That is the basic outline of how the system protects your vehicle.
Hope this helps.
Do you have access to the Porsche Factory workshop/maintenance manuals? If so, there are several explicit electrical diagrams showing the route each switch/wiring takes through out the vehicle. Pretty cool how it was designed originally.
www.clarks-garage.com has a procedure for by-pass if needed.
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 05-17-2009, 12:46 AM
i dont know about a key ill have to look at it later, i do know that i have a 9key pad on my dash that says clifford, and a unit in the engine bay under the horn for the unit,
Old 05-17-2009, 01:06 AM
Check these links, I just installed a remote start on my car about 2 months ago, works well, just have to remember to leave the car in neutral.
I didn't know the factory alarm was a clifford??
http://64.85.6.118/diagrams/diagrams.asp
Grant
89 951
Old 05-18-2009, 05:00 PM
my alarm had a larger blue colored box than that of the clarksgarage example, not sure if that makes a difference. theres also no key turn off switch. though in searching for a switch i found why my car was always eating batteries lol, the lines connecting the parking brake switch were just hanging free touching the seat rails
Old 05-18-2009, 08:17 PM
I believe all alarm equipped models had the external keys through about 1986, so what you have could likely be a completely aftermarket alarm, can you post a picture with part number? Did you look on Clifford's website?
Grant
89 951
Old 05-19-2009, 05:26 AM
heres a pic of what the alram unit looks like, minus the horn that ive already taken out of the car.
this is the alarm control unit im assuming, i cant find any other control locations
Old 05-19-2009, 08:49 PM
In the Fires of Hell.....
kdjones2000's Avatar
That looks aftermarket to me....
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 05-19-2009, 09:24 PM
