My friends call me, Top
Skytrooper's Avatar
Radio wiring
OK...uncle !!
I have been trying to get my radio wired in my '83 944 all evening. I can't seem to make heads or tails out of the wires
Can anybody help me ?
Matt
'87 924S
Old 05-19-2009, 04:50 PM
Not sure how much this will help, but this is what I could find in the shop manuals for the '83:
red/blue wire comes from the ignition switch through the radio relay
red wire from the radio fuse
white wire from/to the antenna
brown wire to ground
speaker pairs as follows;
there is a brown wire for each channel (left - right) that goes to the front and rear speaker
left channel has a brown/red wire that goes to the speaker balance through a connector
pin 4 will be a blue wire
pin 5 brown going out to a brown/red wire to the front left speaker
pin 6 black going out to a brown/red wire to the rear left speaker
right channel has a brown/red wire that goes to the connector
pin 3 will be a red wire
pin 2 green going out to a brown/red wire to the front right speaker
pin 1 green going out to a brown/red wire to the rear right speaker
This isn't a lot, but it's all the manual says about the radio in the schematics. Good luck!
'86 944 Turbo
You have to be a masochist to love something so frustrating.
Old 05-19-2009, 07:29 PM
85Porsche944's Avatar
Would this also be applicable to an early 85?
Old 05-20-2009, 05:33 AM
thekidd's Avatar
Send a message via AIM to thekidd
I think this (post #2) would eb acceptable in the early 85's. I will go out to my '84 to see if it matches up to confirm. I used to have a radio manuel that had the exact information that you need, but Im not sure if its in the car, or where it is now.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 05-20-2009, 08:06 AM
Check these links for wiring info.
http://64.85.6.118/diagrams/diagrams.asp
Grant
89 951
Old 05-20-2009, 12:40 PM
Skytrooper's Avatar
Thanks all ! I got it working !
Matt
'87 924S
Old 05-20-2009, 12:56 PM
