Ign Lock Cylinder
Is it possible to remove and replace the steering lock cylinder on a 1986 944 without pulling the steering wheel and stripping hardware from the steering column?
Please advise and/or provide guidance.
85.5 944na Automatic V-65 Magna 94 Impala SS |
I am almost certain that the steering wheel does have to come off.
They have a great, step by step write up on www.clarks-garage.com. ![]() Click on "Garage Shop Manual" on the left and scroll down to ignition.
John '87 944 N/A (first Porsche) '95 E-350 Diesel '03 S-Type Jag 3.0 '03 Taurus SES '06 Eddie Bauer Explorer RIP SoCal |
Ign Lock Cylinder
Better late than never. I just saw your post. If you haven't already pulled the steering wheel it has to be done. Clarks Garage shows how to do it, but the lock they show is an early 944. Your 86 has two torque bolt that the heads break off and have to be drilled out. This will require you to pull the dash out far enough to use the drill and easy outs to remove the bolts. That is IF you have to change out the entire lock. I was lucky enough that all I had to change was the unit at the rear of the key switch with the male plugs, two little screws. I had to break off the handle of a short stubby common screwdriver and grind down the sides (Now a special tool.) I used a pair of small long nose vise grips on the short shank of the screw driver to break the screws loose and out it came.
Best of luck, Larry
