'87 944S Heater Shutoff valve location
AC does not work so I need to shut off flow off HOT (160 degree) water to heater core using system valve under hood. Cannot locate valve. If you know location please be very precise.
Thanks!!! |
heater control valve?
look under the hall sensor and power steering reservoir. Water pump - hose - heater control valve - hose - hard pipe. Can't miss it.
Warren '87 944S "Tubes sound better" |
Hall Sensor
Thanks for the prompt reply.
Whats a Hall Sensor? |
Thank You
Thanks for your help!!
I found it. |
