My friends call me, Top
Skytrooper's Avatar
Intermittant no start
Hey guys, my '83 944 just recently began having trouble...occasionally...starting. It usually was the first start of the day. I thought since it was cranking really good that I would check the fuel flow (30second test). That was fine. Next I checked for spark, that too was fine. The odd thing was that if you walked away for 5 minutes and came back and tried to start it again...it would fire right up. I figured that it might be a good time to replace the DME relay. This seemed to cure 95% of the no-starts. Unfortunately for me it has become more random. Last week alone it left me stranded for over an hour (after being driven) each time before it would finally start. This car is my DD so you can see where it is a significant problem. Could the DME itself be dying ?
Matt
'87 924S
Old 07-27-2009, 06:07 AM
In the Fires of Hell.....
kdjones2000's Avatar
The solder joints in the DME could be the problem, as well as the connections for the Speed/Reference sensors.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 07-27-2009, 06:25 AM
Skytrooper's Avatar
I have a spare DME. I guess I will swap it out and see if it helps.
Matt
'87 924S
Old 07-27-2009, 07:31 AM
My car does that, there is no spark until you wiggle the reference sensor harnesses. Try that. Those connections get loose sometimes.
Old 07-27-2009, 11:36 AM
Professional Bull5hiter
Outback Porsche's Avatar
I had this same issue until I replaced the sensor wiring harness (from Lindsay Racing) and both sensors. Use the BMW sensors 12-14-1-708-619-M14, they are half the price.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 07-27-2009, 03:27 PM
1984 porsche 944 na
ballysdad's Avatar
+3 on the sensors and or connections
1984 Red NA/Sold
1984 Gray NA/Sold
1986 Red NA
1986 Gray NA
Old 07-27-2009, 05:43 PM
Registered Speed Offender
Crazy Horse's Avatar
One more vote for sensors...They'll surprise you. All will be OK and then your car won't start. Testing info is on Clark's Garage website. It worked for me (a reference sensor)......
Crazy Horse
______________
1989 930
Old 07-27-2009, 06:18 PM
alittle OT but does the speed sensor go bad as offen as the reference, or is it better to replace both when one fails?
Old 07-27-2009, 09:39 PM
It'd be a pretty safe bet that if one connector is failing, the other one will be not far behind. They can be a PITA to get out - while your in there you may as well save yourself a headache latter and replace them both at the same time.
Jeff
83 944 Guards Red
23 718 GT Silver
Old 07-27-2009, 09:57 PM
WestonP22's Avatar
My car has the same issue... Closer inspection revealed that there was some missing insulation and the wire was exposed. The car will not start, and the tach will not bounce while cranking, if the reference sensor is disconnected or inoperative. But once you get it started, it will not die if you unplug the reference sensor, and the tach will continue to work as well, but your ignition timing will be retarded a bit. The speed sensor, on the other hand, will kill the engine the very instant it loses its connection.
#22 RaceRender.com Porsche 944
Old 07-27-2009, 11:07 PM
