'87 944S Heater Shutoff valve location
AC does not work so I need to shut off flow off HOT (160 degree) water to heater core using system valve under hood. Cannot locate valve. If you know location please be very precise.
Thanks!!!
Old 07-31-2009, 04:44 AM
heater control valve?
look under the hall sensor and power steering reservoir. Water pump - hose - heater control valve - hose - hard pipe. Can't miss it.
Warren
'87 944S
"Tubes sound better"
Old 07-31-2009, 06:36 AM
Hall Sensor
Thanks for the prompt reply.
Whats a Hall Sensor?
Old 07-31-2009, 07:28 AM
Thank You
Thanks for your help!!
I found it.
Old 08-02-2009, 02:13 AM
Tags
heater valve
