Dirty little kitty
PorscheKitty's Avatar
Send a message via AIM to PorscheKitty Send a message via Yahoo to PorscheKitty Send a message via Skype™ to PorscheKitty
Unhappy Vents are possessed! And my radio sux ;_;
So, my a/c blows cold out the main two vents in the middle of the dash. The two outer vents seem to blow ambient air...but the feet are blowing scorching hot. What the heck? Anybody hear/know about something like that happening? lol. Help! I wanna cool my feet down. So Cal is too hot ;_;
And I always get air blowing out the vents even with the recirculate button on...?
And the sliding switch things between the temp control and fan speed knobs, which I assume control what vents open up, doesn't work properly. I don't have an orig. owner's manual so I could be wrong about their purpose, lol.
Oh and my radio antenna which is in the windshield gets no reception. I found a wire at the bottom passenger side of the glass that looks like it's supposed to plug into something but there's no connector there. I'm assuming thats why my radio sucks. Is it a special type of connector or can I find a little connector for it at like radio shack or something
Thanks guys. Couldn't find anything on the vents so if I overlooked something and double posted, I'm sorry *pouty face*
Old 07-14-2009, 07:25 PM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
What year do you have? If it's a 85/2 or higher, then check this to make sure this isn't broken.
http://www.kronowit.com/porsches/944-heater-fix.html
Not sure about the radio issue. I would think you could find something
If it's an early, then you probably need to check the hot water valve for operation and/or cable adjustment.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 07-14-2009, 09:18 PM
Dirty little kitty
yeah, tis a late model. My '88
Old 07-14-2009, 11:10 PM
Ornery Bastard
The wire coming out of the windshield on the passenger side is indeed the antenna lead. Many times this is left disconnected (or is damaged) when the windshield is replaced by a "budget" glass company. I don't know specifics about the connector but if that wire is disconnected you will definitely have poor reception.
As for the vent controls, here's a link to a 1988 Owner's Manual.
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 07-15-2009, 07:10 AM
bearone2's Avatar
"socal is hot", you don't know what hot really is.
perhaps the recirc button circuit has a vac leak.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 07-15-2009, 09:08 AM
Dirty little kitty
Hey we got death valley, az boi
Old 07-15-2009, 10:30 AM
bearone2's Avatar
do you live/work/have any relatives in death valley, didn't think so?
Old 07-16-2009, 09:42 AM
*looks at thermometer that says 115*
you cant compare our/az heat with socal heat my dear friend. humidity and 90+ degrees to them feels like our 120 summer days
1983 944 Guards Red (87' Implant Complete)
Old 07-16-2009, 10:39 AM
i have a friend that just completed the badwater marathon - - 135 miles starting in Death Valley, goes through Death Valley and ends at Mt. Whitney Portal.
This is a non-stop footrace. She did it in under 40 hours.
Crazy!
Warren
'87 944S
"Tubes sound better"
Old 07-16-2009, 01:05 PM
bearone2's Avatar
what time of the year do they run the race, i bet in non summertime.
Old 07-17-2009, 07:02 AM
in summer... they just finished a day or two ago.
how's that for hot?
crazy!
Warren
'87 944S
Old 07-17-2009, 09:24 AM
Dirty little kitty
jeebus. And i've lived in barstow which easily gets up to 115 so stfu. I needed help with stuff not talking about the weather.
Old 07-20-2009, 02:51 PM
Custom User Title
mikepellegrini's Avatar
Another possibility for the poor radio reception is that the late cars with the antenna in the windshield used antenna amplifiers - which often get unhooked and forgotten about.
My 951 had the same problem - I hooked up the amp and presto-chango, the radio worked perfectly.
If I remember correctly, the wire to the amp was a small (say 16 or maybe 18 Ga) black wire in the vicinity of the antenna connector.
You hook it up to +12 VDC.
On mine, I hooked it up to a 12 VDV out from the deck. If you use some other source, be sure to fuse it (maybe 5 amps or something low).
Do of course, make sure you've got the correct wire before you give it the voltage. To test mine, I think I had the radio out but plugged in and playing - I brushed the wire quickly with a 12 VDC source and the reception was intantly good.
Then after confirmation, I wired it into the deck.
As for the vents, like the other guys said it might very well be a vacuum hose off somewhere on the vent system. All the vent doors are vacuum controlled. You'll just have to poke around down under your dash and see if you can find it.
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 07-20-2009, 09:17 PM
Dirty little kitty
sweet thanks
Old 08-29-2009, 03:01 AM
Hi Kitty, Check out clarks-garage (home) for helpful info on your Porsche.
http://www.clarks-garage.com/shop-manual/repair-procedure-index3.htm
Cheer,
Larry
Old 08-29-2009, 09:40 AM
