KYB shocks, any good?
My 944 needs shocks and the KYB's seem rather cheep. But are they any good? Anyone here running those?
Old 10-10-2009, 01:11 AM
Proprietoristicly Refined
John_AZ's Avatar
1. Koni
2. Bilstein
3. Boge/Sachs---I use these. OEM. Comfortable ride for daily driver
Do you wonder why none of the major Porshe parts suppliers lists KYB?
?. KYB
GL
John_AZ
1988 924S + 1987 924S
Old 10-10-2009, 05:15 AM
flash968's Avatar
i have run kyb for years on a number of cars, including 944s - they are a decent shock, especially on light cars (the 944 is pretty heavy) - that being said, they work fine for a street car, but tend to be a bit soft for anything beyond that - a commuter would be ok - an autocross car would not - also, the valving is not particularly linear
they do have a lifetime warranty though
does that help?
Old 10-10-2009, 09:13 AM
KYB aren't bad for a stock car, but like others have said they are very soft.
-Alex-
1992 Porsche 968 (07K 2.5L I5 transplant in work)
2003 Porsche 911 Turbo (Arctic/Black, 6MT, X50)
1983 Audi Ur-Quattro(MC1, GT2871R, 034 IIc, Coilovers, Brembos, etc)
Past P-Cars: 1987 Porsche 944 Turbo, 1980 Porsche 924 Turbo, 1987 Porsche 924S
Old 10-10-2009, 09:25 AM
Send a message via AIM to ScoobySteve
KYB does the OEM shocks for many Japanese cars. Most notably, they do the struts for Subarus, including the inverted ones for STi's.
With that said, even when the valve is right, they seem to screw up the ride / handling balance. Over on the Subaru forums the adjustable KYB are the cheapest stiffer option, but they will make your car ride like a truck. Everyone knows if you want it to ride more like a BMW, get Konis or the Tokicos. The stock units also lack any durability. Even very light lowering (less than 1") seems to cause failure within 40,000 miles.
I think my Porsche mechanic said it best when he told me he had installed 4 sets of KYBs at the behest of customers and every single one of them changed them out within 12 months.
-Stephen
00 Boxster S 6MT
03 Subaru WRX w/EJ207 swap
16 Cayman GT4
21 Genesis G70 3.3T
Old 10-10-2009, 10:51 AM
ernie9944's Avatar
For some 24 years I use Boge sport shocks on my 944 ,in march this years I had switch to Sachs in the front since the old one were done with,din't notice any difference in handling or ride, in my opinion they are #1 for street use,without breaking your piggy-bank.But again handling & ride on a 944 is a combination off many things included tires sizes -wheels and lowering the car (mine was lower 1.5" front 3/4"rear wheels were fuchs 16x7.5 all around-tires were falken 452- 205-55-16frt , 225-50-16 rear)this I found over the years that I own the car would not put any stress either on your motor or drive-train and permit you to spirit drive the car on any kind of roads.So hope the infos will help ******
Old 10-10-2009, 10:59 AM
flash968's Avatar
they definitely don't seem to be the perfect solution on this particular car - the non-linear function of gas seems to be exaggerated in the kyb too - they have been perfect on a number of lighter cars, but with as much weight as the 944, i think the valving is less than optimal
i have never had one fail, including on the sandrail, where it was subjected to horrendous loads and abuse - i'm not sure why they would fail on a 944
however, if they fail, they get replaced, which is a big deal to those who are budget conscious - that can't be said of other shocks
frankly though i am not a fan of any gas shock on the rear - the car works much better with an hydraulic shock - i am currently running double adjustable hydraulic carreras on the blue car - MUCH more civilized than anything else i have seen - i have twice the spring rate of stock and it rides very smoothly, yet controlled in the corners - a lot more money though
Old 10-10-2009, 11:00 AM
ernie9944's Avatar
Sorry off subject,and Flash 968 youre the one witch can problably help me out.The original owner of my 968 did a little suspension mods to the car ,in fact I got the O.E pieces all wrap up in a box, complete struts assemly -springs & rear shocks not many miles on them that for sure.Anyway there it is?? front of the car is 4 3/4" from the ground, the Springs as (porsche 968 va ) written on them, the adjustable strut assembly #19734335201 top with bleu hat. The rear shocks are bilstein #28988535963670-----400-200 ,calipers & rotors look O.E.??? if the top hat is bleu will the insert be Bilstein & what could be the springs rate,the car drive like a GO_KART even at over 150 mph it has very good road handling and the ride is not bad at all. THANK IN ADVANCE
Old 10-10-2009, 11:46 AM
Redline Racer
HondaDustR's Avatar
Yeah, stay away from the KYB's. Mine ended up needing shocks in the front and when I replaced them with Bilsteins, I found they were previously replaced with KYB's. I was never impressed with them, but the Bilsteins are nice for the money.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 10-10-2009, 01:00 PM
Hey thanks a lot for all the responses, looks like it's Bilsteins for me! The price seemed a bit too good to be true. Especially if I upgrade to stiffer springs/bars in the future.
Old 10-10-2009, 04:30 PM
Toofah King Bad
Rasta Monsta's Avatar
I have Billies on my 931. Many people complain that they are harsh, and they likely are on rough roads (roads are good in my area). Great handling!
I have KYBs on the S, they are nothing to write home about in the handling department, but they are a nice mellow ride for the wife, and are way better than the blown ones that I removed!
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 10-10-2009, 04:52 PM
Redline Racer
HondaDustR's Avatar
I would definitely not consider them harsh. They are firm when they need to be, but they ride nicely on the highway, but then again, I run stock 15" wheels/tires/springs.
Old 10-10-2009, 05:32 PM
ernie9944's Avatar
UomoBello sorry I bump in on your tread wasn't bad intents hope I'm forgiven ,still learning here *******
Old 10-12-2009, 09:46 AM
No biggie Ernie!
Old 10-12-2009, 08:52 PM
Ya I put some KYBs on the Corrado cause they were cheap. They don't ride bad... Don't handle like PSS9s though
Old 10-12-2009, 09:19 PM
uvachief
uvachief's Avatar
Send a message via Yahoo to uvachief
Not to revive an old thread but....someone switched out the existing shocks with just KYB insets and rear shocks in August of 2009 or about 10,000 miles ago on my 86 944 na. It rides very smoothely on the highway and city roads. We have some rough cobblestone roads in Richmond. I was going to remove them and install Sachs/Boge inserts. However, a local shop suggested just adding a stiffening brace to the front sway bar, redoing the bushings with OEM rubber and maybe adding a strut brace. Much cheaper than what I had planned. After that, if it still doesnt' handle well, I could then do the Sachs/Boge or Koni inserts with new springs. Thoughts?
Sincerely,
uvachief
1986 944 NA Red 5SPD
Old 05-13-2013, 11:36 AM
AFM #725
Gawernator's Avatar
.....I went from KYB to Koni and it was amazing.
John_AZ pretty much nails it:
"1. Koni
2. Bilstein
?. KYB"
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 05-13-2013, 12:46 PM
If the shop is recommending new bushings -- do them. None of the suspension works right and the car feels loose.
-Stephen
00 Boxster S 6MT
16 Cayman GT4
21 Genesis G70 3.3T
Old 05-13-2013, 02:26 PM
porschetub's Avatar
CHEEP yes,last choice,standard BOGE aren't that expensive
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 05-13-2013, 08:23 PM
Frenchy
I needed some quick cheap temporary replacements so I put KYB's on my 924S about 3 years ago. They were pretty good for the first year but have been going downhill ever since then. Just ordered new Bilstein's.
Good Luck
Frenchy
Old 05-13-2013, 08:49 PM
