My 944.
Hi, Guys. Can you help me with this pesky problem.
I bought my 944 non running; I put a new battery in her and when I turn the key to 'power' all the lights in the dash light up, and I'm getting a loud clicking noise from the cruise control servo. Is my servo DOA, or Do I have some gremlins? |
i hope u didn't pay more than $500 for a non running 944.
more likely than not, it's a bad ground or a short between two wires. take off the kick panels and start checking every which wire to make sure the insulation is still there. |
Non Compos Mentis
DME relay is a common fault. Cheap. easy fix. Stick another one in and see what happens.
Used & Abused
Gremlins
What year?
83 - 944, daily driver 62 - VW Karmann Ghia, never moving restoration "Oh Bother," said Pooh, as he chambered another round. |
Hello My944, A BIG WELCOME TO THE FORUM. There are several things for you to look at. Use the TECH INFO CENTER and the SEARCH Option. For your maintenance info go to the link below and read.
Clark's Garage Shop Manual Index http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/484996-let-start-no-start-checklist.html Cheers, Larry |
For now I would just diconnect it as you have bigger problems and cannot properly test it until the car is running anyway.
That's what I have done so far, along with a new DME relay. The engine won't catch, so I have bigger fishes to fry at the time being. |
